| gooddog29 |
Sep 21 2024, 11:45 AM
I'm new here ... Group: Members Posts: 0 Joined: 30-August 24 From: Williamsburg, VA Member No.: 28,320 Region Association: None
[size=3]
VIN: 4742900144, Built 8/73, Engine No: GA006749, painted 2015 Ford H3 Triple yellow Price: $26,500 Location: Williamsburg VA Previous owner, at approximately 100,000 miles, rebuilt engine to European specs, engines were detuned when imported to US to meet EPA standards. Rebuild included new Cylinders and flat head pistons, Carb cam, Weber carbs, IDF-44. Installed Bursch SS exhaust. SS heat exchanges installed. At approximately 111,000 miles car was fully disassembled, rust spots repaired, repainted inside and out, new interior, side sails. Installed BMW larger front brakes and larger brake master cylinder. During my ownership:starting 12/17 • Fuel tank removed, cleaned, SS fuel lines installed, new pump, fuel pressure regulator and gauge installed • Rear brakes rebuilt by PMB Inc. • Bilstein front shocks installed • Added oil pressure gauge and AFR gauge • Dipstick oil temp gauge installed • New starter, flywheel, clutch and associated hardware • Engine oil galley plugs replaced • New engine mounts installed • Transmission rebuilt with new parts by Evilwerks, LLC • New Optima battery and cables • “123 Ignition” installed, Bluetooth link to smart phone • Valances and running boards refinished in carbon fiber • New seat belts, Targa bar front edge replaced • Full set of Porsche maintenance manuals, other repair manuals, spares, specialty tools included |
| T_14 |
Sep 23 2024, 09:47 AM
I'm new here ... Group: Members Posts: 0 Joined: 29-June 23 From: Austin, TX Member No.: 27,442 Region Association: Southwest Region |
PM sent
Lo-Fi Version | Time is now: 11th September 2026 - 03:16 PM |
