> Out of sight Audio unit., Anyone have any experience with these?
mmichalik
post Oct 10 2024, 02:54 PM
MikeM
I'm going to put this one into my 75, I just received the radio delete plate from 914rubber and will be ordering one of these next.:
https://outofsightaudio.com/product/mark-4/
It's a complete hands free phone hook up and Bluetooth setup, with no need to have a radio. I am planning on just using my phone, since I am a 100% SiriusXM listener, when I'm not listening to Amazon music.
Period correct radios are just way to expensive and don't usually have Bluetooth integrated with them and reproduction radios have digital displays that I don't want in the car.
Wanted to get some opinions from the group.
Millerwelds
post Oct 10 2024, 04:12 PM
Pleepleus
I don't use that exact unit but I have a bluetooth setup to my amps and use my phone as well. Works great. (IMG:style_emoticons/default/beerchug.gif)
jd74914
post Oct 11 2024, 09:34 AM
Its alive
That looks like a nice unit, particularly if you want to make calls. Never used one though.
A buddy has one of these Bluetooth amplifier adapters from Soundstream. It seems to work pretty good too,
https://soundstream.com/product/st4-1000db/
emerygt350
post Oct 11 2024, 10:14 AM
I have this thing in my car. Actually works really well for $18.99. I use it so I can hear the google maps voice, audible, and for phone calls. Radio sounds fine but I prefer listening to vroom vroom sounds while driving the 914.
Nice thing is the most common complaint is the LED is so dim you can't see it. Just what I wanted.
amazon.com classic radio
dr914@autoatlanta.com
post Oct 11 2024, 10:39 AM
I sit my bose speaker on the pass floor and use my phone, great sound and can move from car to carAttached Image
robkammer
post Oct 11 2024, 12:04 PM
Robbo
I put a cheapo 100 watt amp on the upper right hand side of my console, velcro mounted on the inside. I also found the very cool power switch at Summit racing: https://www.summitracing.com/parts/PCO-5585PT.
But the way I positioned the amp I can reach the hidden volume control and just use my phone to control 'Classic Vinyl'!
Speakers ar in 914 Rubber repop boxes.
Works great and invisible.
Rob
Chris914n6
post Oct 11 2024, 03:27 PM
Jackstands are my life.
That's overkill and quite pricey. You will never use handsfree calling in a 914.
All you need is something like this Pyle Amplified Wireless Bluetooth Audio Controller $60
Or get a separate BT to RCA receiver SONRU and whatever amp meets your needs. $20
blabla914
post Oct 11 2024, 07:01 PM
I like primer
QUOTE(dr914@autoatlanta.com @ Oct 11 2024, 08:39 AM) *
I do this too with an Anker sound bar, but i've gotten a little weary of the thing flying around the cockpit whenever I have any fun, so I've been looking at similar units.
Another thing I've been thinking of is just some velcro or some simple mount for my sound bar.
bkrantz
post Oct 11 2024, 07:04 PM
I went old school with this. I hid the main box in the center console and put the control box in the arm rest. It connects to my phone via usb, but works without it.
https://clarionmarine.com/products/cms20-ma...urce-units92707
Front yard mechanic
post Oct 11 2024, 07:50 PM
I use the same unit that I use in the shower. Lalala la
mlw914
post Mar 8 2025, 05:50 PM
I am going to give this one a try. I don't mind the small LED display as the car is a 3. conversion and not completely stock interior either. Pretty economical as well and will mount well with other round gauges in the center console.
https://www.crutchfield.com/p_20646KMC2/Kicker-46KMC2.html
DC_neun_vierzehn
post Mar 9 2025, 06:04 AM
I kept my Blaupunkt Frankfurt in the dash for aesthetics but have this little sucker (Amazon $30) hidden under my dash so that I can stream from my phone It puts out plenty of power to the 7.5” speakers in the 914 Rubber pods. Sounds terrific.
https://www.amazon.com/Bluetooth-Amplifier-...78058&psc=1
JmuRiz
post Mar 9 2025, 11:05 AM
QUOTE(DC_neun_vierzehn @ Mar 9 2025, 04:04 AM) *
Good idea, I was thinking of mounting my Becker Europa in the dash and something else in the top of the deposit box for other tunes.
Question: can you run speaker wires from each to the speakers? Use the Europa for radio and the other streaming tunes?
barefoot
post Mar 10 2025, 07:33 AM
I installed a JVC bluetooth radio in the standard dash location with mic located next to speedo under dash hood. Not hands free but i listen to my Spotify music from phone.
no other equipment used.
Barefoot
DC_neun_vierzehn
post Mar 10 2025, 01:09 PM
QUOTE(JmuRiz @ Mar 9 2025, 12:05 PM) *
Not sure. I never used my radio so I didn't consider doing this. I would think you should be able to do that. You would just want to make sure you didn't do both at the same time to prevent possible damage to the speakers.
rfinegan
post Mar 10 2025, 06:16 PM
I have a vintage Blaupunkt stereo and a $100.00 Blue tooth
adapt that plug right into the din connector on the back. works GREAT and and self switching from radio
- Lo-Fi Version Time is now: 2nd April 2026 - 12:59 AM
