| BillC |
Nov 2 2024, 05:06 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 701 Joined: 24-April 15 From: Silver Spring, MD Member No.: 18,667 Region Association: MidAtlantic Region
There is a big hole in the driver's side sheet metal of my engine compartment ('73 2.0), towards the front. It is approximately 40mm in diameter, and inboard from the drain hole.
What is it for? And, does anyone sell a plug to fill it? I don't remember a similar hole on my old '73 1.7. And, I don't want to leave such a big hole open, so I need a plug -- I can make one if needed, but I'd rather get the correct part if possible. Here's a pic from the underside. The hole in question is the top-most, just under the rubber engine gasket. |
BillC What is this hole? Nov 2 2024, 05:06 PM
windforfun Somebody added a drain hole. Is there one on the ... Nov 2 2024, 06:32 PM
sixnotfour 914-6 oil return line to tank..left overs from 914... Nov 2 2024, 06:47 PM
Krieger
914-6 oil return line to tank..left overs from 91... Nov 2 2024, 11:43 PM
sportlicherFahrer 914Rubber sells them. Link below.
40mm Body Plug Nov 4 2024, 08:30 AM
Krieger Do not plug the smaller hole next to it. That is ... Nov 4 2024, 08:37 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 07:50 AM |
