| Mr.Vman |
Nov 6 2024, 04:24 PM
Newbie ![]() Group: Members Posts: 31 Joined: 1-October 24 From: Sierra Vista, AZ. Member No.: 28,388 Region Association: Southwest Region |
1976 914 2.0, MPC D Jetronic fuel injection California car. Questions:
To add the center three gauge console. Car has the, DPD AC. Does the console have to be cut down to clear the AC duct? Is there a special upper bracket to mount console to instrument panel. Is there a bracket to console to tunnel? Will non Porsche VDO gauges work with Porsche sending units? Like oil temperature, oil pressure? There is wire harness that can be bought for adding a gauge console, is the wiring already under the instrument panel? DPD AC; Is there a bracket available to mount a Sanden AC compressor instead of the old two cylinder York or Techumseh compressor? The front, in the nose AC condensor. With a retrofit to, 134 refrigerant, does the AC condenser need to be upgraded to a modern condenser? I assume replace the AC hoses? Is there a kit out there for a compressor mount and condenser replacement? Where does the distributor vacuum advance hose attach too? Under the throttle body? Is there only a vacuum hose on retard side of the distributor? No hose on the vacuum advance side (front of distributor)? This will be a good start, thank you in advance, Steve V. |
Mr.Vman New owner questions Nov 6 2024, 04:24 PM
930cabman :wttc:
I would say a different gauge will not wo... Nov 6 2024, 05:00 PM
technicalninja I can comment regarding the AC...
I run an Automot... Nov 6 2024, 06:26 PM
914werke 1976 914 2.0, MPC D Jetronic fuel injection Calif... Nov 6 2024, 07:41 PM
bkrantz The 3 stock gauges are oil temp, volts, and a cloc... Nov 6 2024, 09:02 PM
Eric_Ciampa
1976 914 2.0, MPC D Jetronic fuel injection Calif... Nov 6 2024, 10:28 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 11:37 AM |
