> Solvent question, What to use in a parts washer
billd
post Aug 27 2005, 11:51 AM
What solvent are people running in their parts washers? It doesn't seem possible to get varsol any more. What do people use instead? Mineral spirits? Degreasol?
Replies(1 - 8)
TravisNeff
post Aug 27 2005, 12:15 PM
I had been using the gallon degreasers form Harbor Freight. They are like castrol super clean or simple green type cleaners. Add a gallon of that, fill with water and go.
The instructions of course say not to use flammable solvents like diesel fuel or stoddard solvents.
Gint
post Aug 27 2005, 01:18 PM
Mike Ginter
Real solvent. I get it from the local NAPA parts store. $4 and change a gallon. Lasts forever as much as I use it.
mharrison
post Aug 27 2005, 04:05 PM
Why do I bother????
Mineral Spirits....
bd1308
post Aug 27 2005, 04:18 PM
Sir Post-a-lot
isnt mineral spirits flammable tho?
sure smells like it
SpecialK
post Aug 27 2005, 04:26 PM
aircraft surgeon
If you go with a solvent based cleaner, just make sure that the flash point is above 140F.
We used to use trichloroethane (non-flammable), worked great! Not so good for the ozone and your brain cells. (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif)
Mark Henry
post Aug 27 2005, 04:56 PM
that's what I do!
QUOTE (bd1308 @ Aug 27 2005, 06:18 PM)
sure smells like it
Yes but it has a high flashpoint....add water to it and even though they don't mix (the water goes to the bottom) it raises the flash point even higher.
Adding water also turns the dirt into a goo, that can be lifted right off of the bottom of the tank.
bd1308
post Aug 27 2005, 05:08 PM
Sir Post-a-lot
cool.
learn something new everyday.
partwasher.... (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif) i could use one of those...
qa1142
post Aug 27 2005, 05:37 PM
Whiplash
I picked up the 3.5 gal unit from Harbor Freight. I have a store ~ 15 minutes away. Guess I'll add a little water to bottom too! (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif)
- Lo-Fi Version Time is now: 7th March 2026 - 03:28 AM
