Mikey914 |
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,772 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None ![]() ![]() |
I have a few sets of these ready, and can do up a few more if there is interest.
This is a great way to spruce up the bottom side when you do a valve adjust. Comes with, 2 freshly powder coated valve covers, 914Rubber thicker cork seals, 8 old school heavy wall push rod tubes with the dimple to help seat them , and 914arubber Viton seals. 8 tubes that are polished. I would like to sell on an exchange basis, but want to assure I get cores back. $100 for the parts exchange, $50 core charge paid upon return. $100 + $11.20. USPS priority mail flat rate covers anywhere in the US. 2 sets ready to go right now. Valve covers only (includes cork gaskets) powder coated $35 - $20 core $55 Shipping priority mail add $11.20. Attached thumbnail(s) ![]() |
Mikey914 |
Not a great shot, but put these on my 72 before I sold it.
bdstone914 |
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,015 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
I think that type of pushrod tube was used up to 73 in 1.7L engines.
They went to the later smaller diameter push rods. Possibly due to the larger exhaust tubes on 2.0 and 1.8 engines. I have sold many sets of these thinking there was no functially difference. Has anyone used the larger diameter tubes on a 2.0 or 1.8 and if so were the push rod tubes touching the exhaust tubes? |
Mikey914 |
I have used on 2.0 heads as well as the 1.7. Assuming 1.8 would be the same???
bdstone914 |
I have used on 2.0 heads as well as the 1.7. Assuming 1.8 would be the same??? The tubes will fit all heads except the cery earlt 1.7 heads which have a smaller opening for the tube and use a different size o ring. The heat exchangers for 1.7 are smaller diameter than 1 8 and 2.0. The possible issue is clearance from the push rod tube to the exhaust tube. 2.0 and 1 7-1.8 SSI exchangers have the same size id tubes. nit sure if their OD is the same as stock exchangers as the tube wall is thinner. |
Mikey914 |
Tube wall on these is definitely thicker. It's one of the features I like about these. No problems on my 1.7 or 2.0. You don't have to be as careful with them, worrying about crushing them, when you grab them to force into the heads and block.
burton73 |
Senior member, and old dude ![]() ![]() ![]() ![]() Group: Members Posts: 3,848 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California ![]() ![]() |
Just curious on the push rod tubes, was there a coating or plating (like silver Zinc) on these from the factory to stop rust forming? If they are polished, they would plate well
Best Bob B |
bdstone914 |
Just curious on the push rod tubes, was there a coating or plating (like silver Zinc) on these from the factory to stop rust forming? If they are polished, they would plate well Best Bob B Factory finish was yellow cad or zinc. They usually leak enough oil to prevent rust. |
Mikey914 |
These were polished only. So the silver zinc has a coat of wax on them.
Mikey914 |
Still have a set left
gtbarnes |
Newbie ![]() Group: Members Posts: 35 Joined: 9-July 13 From: nash,tn Member No.: 16,111 Region Association: South East States ![]() |
I have used on 2.0 heads as well as the 1.7. Assuming 1.8 would be the same??? The tubes will fit all heads except the cery earlt 1.7 heads which have a smaller opening for the tube and use a different size o ring. The heat exchangers for 1.7 are smaller diameter than 1 8 and 2.0. The possible issue is clearance from the push rod tube to the exhaust tube. 2.0 and 1 7-1.8 SSI exchangers have the same size id tubes. nit sure if their OD is the same as stock exchangers as the tube wall is thinner. I have seen oem tubes hammered for clearance, apparently to get a socket/extension on the exh port studs(which is real tight space to start with on certain cyls). Not sure if there was a part mismatch involved or just some idiot working on it... |
914outlaw |
Dave ![]() ![]() Group: Members Posts: 202 Joined: 2-June 10 From: Central, NJ Member No.: 11,800 Region Association: North East States ![]() ![]() |
Mikey914 |
Responded to via PM
gtbarnes |
Mikey914 |
Responded to via PM So its $161.20 and if I send in my reworkable cores I get $50 back, is that right? TY Mikey Yes that is correct net is 111.20 shipped domestically USPS. These have been hanging around awhile, I'd drop it to $100 (after cores recieved). Mark |
Lo-Fi Version | Time is now: 30th June 2025 - 07:58 PM |
