| Mikey914 |
Dec 9 2024, 09:15 PM
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,772 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None
I have a few sets of these ready, and can do up a few more if there is interest.
This is a great way to spruce up the bottom side when you do a valve adjust. Comes with, 2 freshly powder coated valve covers, 914Rubber thicker cork seals, 8 old school heavy wall push rod tubes with the dimple to help seat them , and 914arubber Viton seals. 8 tubes that are polished. I would like to sell on an exchange basis, but want to assure I get cores back. $100 for the parts exchange, $50 core charge paid upon return. $100 + $11.20. USPS priority mail flat rate covers anywhere in the US. 2 sets ready to go right now. Valve covers only (includes cork gaskets) powder coated $35 - $20 core $55 Shipping priority mail add $11.20. Attached thumbnail(s) |
| Mikey914 |
Dec 11 2024, 10:52 PM
I have used on 2.0 heads as well as the 1.7. Assuming 1.8 would be the same???
| bdstone914 |
Dec 12 2024, 05:55 AM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,233 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
I have used on 2.0 heads as well as the 1.7. Assuming 1.8 would be the same??? The tubes will fit all heads except the cery earlt 1.7 heads which have a smaller opening for the tube and use a different size o ring. The heat exchangers for 1.7 are smaller diameter than 1 8 and 2.0. The possible issue is clearance from the push rod tube to the exhaust tube. 2.0 and 1 7-1.8 SSI exchangers have the same size id tubes. nit sure if their OD is the same as stock exchangers as the tube wall is thinner. |
Mikey914 FS lower engine spruce up kit- push rod tubes, valve covers with seals Dec 9 2024, 09:15 PM
Mikey914 Not a great shot, but put these on my 72 before I ... Dec 9 2024, 10:42 PM
bdstone914 I think that type of pushrod tube was used up to 7... Dec 10 2024, 06:02 AM
gtbarnes
I have used on 2.0 heads as well as the 1.7. Ass... Feb 5 2025, 03:09 AM
Mikey914 Tube wall on these is definitely thicker. It's... Dec 12 2024, 12:11 PM
burton73 Just curious on the push rod tubes, was there a co... Dec 12 2024, 02:20 PM
bdstone914
Just curious on the push rod tubes, was there a c... Dec 12 2024, 04:05 PM
Mikey914 These were polished only. So the silver zinc has a... Dec 16 2024, 12:29 AM
Mikey914 Still have a set left Feb 4 2025, 03:18 AM
914outlaw
I’d like a set. Feb 6 2025, 02:46 AM
Mikey914 Responded to via PM Feb 7 2025, 01:10 AM
gtbarnes
Responded to via PM
So its $161.20 and if I... Feb 13 2025, 06:35 AM
Mikey914
Responded to via PM
So its $161.20 and if ... Feb 17 2025, 12:00 PM![]() ![]() |
Lo-Fi Version | Time is now: 19th January 2026 - 06:10 PM |
