> 914World Classifieds Rules
> FS lower engine spruce up kit- push rod tubes, valve covers with seals
Mikey914
post Dec 9 2024, 09:15 PM
The rubber man
I have a few sets of these ready, and can do up a few more if there is interest.
This is a great way to spruce up the bottom side when you do a valve adjust.
Comes with, 2 freshly powder coated valve covers, 914Rubber thicker cork seals, 8 old school heavy wall push rod tubes with the dimple to help seat them , and 914arubber Viton seals. 8 tubes that are polished.
I would like to sell on an exchange basis, but want to assure I get cores back.
$100 for the parts exchange,
$50 core charge paid upon return.
$100 + $11.20. USPS priority mail flat rate covers anywhere in the US.
2 sets ready to go right now.
Valve covers only (includes cork gaskets) powder coated $35 - $20 core $55
Shipping priority mail add $11.20.
Mikey914
post Dec 11 2024, 10:52 PM
The rubber man
I have used on 2.0 heads as well as the 1.7. Assuming 1.8 would be the same???
bdstone914
post Dec 12 2024, 05:55 AM
bdstone914
QUOTE(Mikey914 @ Dec 11 2024, 10:52 PM) *
The tubes will fit all heads except the cery earlt 1.7 heads which have a smaller opening for the tube and use a different size o ring. The heat exchangers for 1.7 are smaller diameter than 1 8 and 2.0. The possible issue is clearance from the push rod tube to the exhaust tube. 2.0 and 1 7-1.8 SSI exchangers have the same size id tubes. nit sure if their OD is the same as stock exchangers as the tube wall is thinner.
gtbarnes
post Feb 5 2025, 03:09 AM
QUOTE(bdstone914 @ Dec 12 2024, 03:55 AM) *
I have seen oem tubes hammered for clearance, apparently to get a socket/extension on the exh port studs(which is real tight space to start with on certain cyls). Not sure if there was a part mismatch involved or just some idiot working on it...
- Lo-Fi Version Time is now: 15th February 2026 - 11:04 PM
