When best to check Oil Level?, Green 'oil' lite flickering |
Scott Carlberg |
Jul 29 2003, 10:45 PM
Porsche MOTORSPORTS Group: Members Posts: 1,595 Joined: 17-April 03 From: Modesto, Ca Member No.: 580 |
Ok, with my '73 1.7, the [COLOR=green]Green[/COLOR=green] Oil Lite keeps
flickering on & off. When exactly is the best time to check the Oil Level? Cold? Hot? Warmed up a couple of minutes? If the lite is coming on, I usually check the level 5-10 minutes after getting home. Is that Good or Bad? And finally... is the Green Lite ONLY for the Oil Level, or does it serve another purpose also? |
Brad Roberts |
Jul 29 2003, 11:36 PM
Scott.. your going to burn up another engine.
Check the oil once a week. The volume of oil doesnt change with heat... but it does drain back quicker to the bottom of the engine (which could read more). Check it hot or cold... just check it once a week. Dont wait on the light. B |
MarkV |
Jul 29 2003, 11:42 PM
Ummm... the green light comes on when you have no oil pressure. I suppose you could call it a oil level indicator because if you have no oil you have no oil pressure. (IMG:style_emoticons/default/icon8.gif)
The oil level is best checked cold before you start the car. Cold will give you the most accurate reading on the dipstick. |
redshift |
Jul 30 2003, 02:21 AM
Check it cold, and when it's full, add one pint.
Uhh, make sure the car is level. (thanks for reminding me karl.. your sig file..) M |
Scott Carlberg |
Jul 30 2003, 02:41 AM
QUOTE(Brad Roberts @ Jul 29 2003, 10:36 PM) Scott.. your going to burn up another engine. Check the oil once a week. The volume of oil doesnt change with heat... but it does drain back quicker to the bottom of the engine (which could read more). Check it hot or cold... just check it once a week. Dont wait on the light. B I'm NOT doing it! When I drive the car alot, I'm putting a quart in every 10-14 days. It's leaking (NO! a german aircooled engine leaking?) but the oil is also going right thru the engine somewhere. My local mechanic still thinks I got a good deal: $500 including the install. (IMG:style_emoticons/default/unsure.gif) Ok, thanks all. I will check it when it's cold. I've been checking it when it's warm, because I thought that was the way to do it. It's really no wonder why I don't do stuff to my car (IMG:style_emoticons/default/confused24.gif) |
Mueller |
Jul 30 2003, 07:48 AM
500 for a motor and an install??
That is a great deal, even if it is leaking some oil.......... |
ChrisReale |
Jul 30 2003, 10:12 AM
I have read that it is best to check the oil level when the car is warmed up. What is the final answer?
redshift |
Jul 30 2003, 10:42 AM
When it's cold, and level, you know where the oil is, so when it's on the line, you can still add that extra pint or so with complete confidence.
M |
Elliot_Cannon |
Jul 30 2003, 01:41 PM
Senior Member Group: Retired Members Posts: 1,922 Joined: 26-March 03 From: Orange County Ca Member No.: 480 Region Association: None |
QUOTE(ChrisReale @ Jul 30 2003, 08:12 AM) I have read that it is best to check the oil level when the car is warmed up. What is the final answer? Hi, I check my 911 when the engine is hot and running. I check the914/4 when it is cold and stopped. Since my 914 hasn't run in 8 months I check it everyday!! (IMG:style_emoticons/default/laugh.gif) Cheers, Elliot |
rhodyguy |
Jul 30 2003, 04:24 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,060 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
take a paper towel and check it EVERYTIME, before you start it for the first time during the day. it takes what, 30 seconds?
kevin |
nebreitling |
Jul 30 2003, 04:26 PM
QUOTE(Elliot Cannon @ Jul 30 2003, 11:41 AM) \ I check my 911 when the engine is hot and running. I check the914/4 when it is cold and stopped. (IMG:style_emoticons/default/agree.gif) this is precisely what i thought. |
ChrisReale |
Jul 30 2003, 07:23 PM
QUOTE(Elliot Cannon @ Jul 30 2003, 12:41 PM) QUOTE(ChrisReale @ Jul 30 2003, 08:12 AM) I have read that it is best to check the oil level when the car is warmed up. What is the final answer? Hi, I check my 911 when the engine is hot and running. I check the914/4 when it is cold and stopped. Since my 914 hasn't run in 8 months I check it everyday!! (IMG:style_emoticons/default/laugh.gif) Cheers, Elliot Hot and running? So, do you have somebody else steer while you climb into the engine compartment? (IMG:style_emoticons/default/laugh.gif) I check my Subaru while it is cold. I just read om Pelican you should do it while the oil is warmed up. It makes sense to check the level when it is cold (IMG:style_emoticons/default/headbang.gif) |
Bruce Allert |
Jul 31 2003, 07:44 AM
Hellions asleep Group: Members Posts: 3,289 Joined: 19-March 03 From: Eagle Creek, Orygun Member No.: 441 Region Association: Pacific Northwest |
QUOTE(ChrisReale @ Jul 30 2003, 06:23 PM) It makes sense to check the level when it is cold (IMG:style_emoticons/default/headbang.gif) Think about it... the car is cold (been sitting 6-8 hrs.) all the oil (or most of it) is drained down sit'n around that stick thingy that lets you know where the oil level is??? (IMG:style_emoticons/default/idea.gif) Less chance of an over fill (IMG:style_emoticons/default/cool_shades.gif) bruce |
Mark Henry |
Jul 31 2003, 08:30 AM
Hot or cold it doesn’t really matter to me.
The big issue is to make sure the car is on level ground! The Type 4 engine dipstick is grossly affected by how the car is sitting. I check my cars cold in the shop (my drive is on a hill) and/or I only use gas stations with a level pad at the pumps. I pump my gas then check my oil, religiously. (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 25th April 2024 - 09:34 AM |
