| PaIsa |
Jan 1 2025, 09:25 AM
Member ![]() ![]() Group: Members Posts: 133 Joined: 13-June 24 From: Quebec, Canada Member No.: 28,180 Region Association: Canada
So I tried to replace the o-rings on the push rod tubes. I was able to pull 3 out of the 8 tubes using pliers but I cannot believe that there is not an easier and more efficient way of pulling those tube out. Not saying that using pliers, even when being careful, there is a risk of damaging the tube.
Does anyone know of a tool to get them out? I would see some kind of expanding device that fits inside of the tube with a kind of slide hammering device to get them out. I am pretty sure that someone that does this routinely will have a tool! |
PaIsa Push rol tube removal Jan 1 2025, 09:25 AM
rfinegan I have had pretty good luck wrapping a shop rag ar... Jan 1 2025, 10:05 AM
PaIsa
I have had pretty good luck wrapping a shop rag a... Jan 2 2025, 10:05 AM
technicalninja Get them to rotate first, I use lots of WD/40 here... Jan 1 2025, 10:36 AM
GregAmy Not helpful to your immediate problem, but I'm... Jan 1 2025, 11:08 AM
930cabman
Not helpful to your immediate problem, but I... Jan 1 2025, 03:43 PM
Aerostatwv I crack them loose with a pair of vice grips by tw... Jan 1 2025, 11:33 AM
Jack Standz What everyone else said and have had good luck wit... Jan 1 2025, 03:31 PM
cgnj Hose pilers are your friend. Jan 2 2025, 10:51 AM
porschetub
:agree: that's... Jan 3 2025, 07:53 PM
PaIsa
Pliers were the to... Jan 3 2025, 09:31 PM
brant
Pliers were the t... Jan 4 2025, 09:33 AM
KELTY360
[quote name='PaIsa' post='3184834' date='Jan 3 20... Jan 4 2025, 10:47 AM
Montreal914 Before reinstalling them with the proper viton O-r... Jan 4 2025, 09:27 AM
76-914 Strap Wrench! Jan 4 2025, 09:29 AM
technicalninja :agree: :agree: :agree:
I grease the crap out ... Jan 4 2025, 12:51 PM
emerygt350 I have had pretty good luck beating them back into... Jan 4 2025, 08:23 PM
PaIsa I will probably get back at it this week end with ... Jan 6 2025, 06:15 AM
cgnj It is difficult to fit pliers or vice grips betwee... Jan 6 2025, 06:22 AM
PaIsa Just to close this, I finally ended up buying a se... Feb 13 2025, 12:34 PM
rjames The one and only time I replaced a push rod tube I... Feb 13 2025, 06:25 PM![]() ![]() |
Lo-Fi Version | Time is now: 1st April 2026 - 06:47 PM |
