| jeff |
Jan 6 2025, 11:22 AM
Member ![]() ![]() Group: Members Posts: 256 Joined: 17-January 04 From: thousand oaks,ca Member No.: 1,570 |
I’m getting closer to painting this 914 project. Is it worth making an access panel to the fan belt area of the engine? It’s a 3.2/6 if so how big should the hole be?
Attached thumbnail(s) |
| BillJ |
Jan 6 2025, 11:37 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,355 Joined: 4-March 13 From: charlotte, NC Member No.: 15,610 Region Association: None
Yes it is worth it for sure imho. Makes things like tightening the fan belt, oil lines access, electrical wiring access, cleaning, etc easier.
| SirAndy |
Jan 6 2025, 11:42 AM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,469 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Just remember, it's called a "Fire Wall" for a reason.
(IMG:style_emoticons/default/stirthepot.gif) Make sure you got plenty of overlap on the panel, use quality fasteners and don't use any sort of flammable seal. (IMG:style_emoticons/default/driving.gif) |
| dr914@autoatlanta.com |
Jan 6 2025, 12:18 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,232 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
| mlindner |
Jan 6 2025, 01:37 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,748 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest
| 930cabman |
Jan 6 2025, 04:23 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,571 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States
yes, makes things much easier. Fit the panel reasonably tight (I added about 5/8" around the perimeter and hold it in place with a couple pop rivets.
It is a firewall, but nobody has fireproof glass in their rear window |
| mb911 |
Jan 6 2025, 04:40 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,728 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest
No just tilt the engine back. Just did it on my car and have a thread about it pretty recently. Cutting the firewall is literally playing with fire
| ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,542 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille
I’m getting closer to painting this 914 project. Is it worth making an access panel to the fan belt area of the engine? It’s a 3.2/6 if so how big should the hole be? no (IMG:style_emoticons/default/agree.gif) Having lived through an engine fire in a 914, I will not cut holes in anything called a "firewall". (IMG:style_emoticons/default/screwy.gif) If you have a 3.6, get a Clewett serpentine belt kit. It makes it a breeze to change the belt just by moving the tensioner. Here's a picture of it on my motor before I put it in. (IMG:http://www.914world.com/bbs2/uploads/post-1143-1475889671.jpg) Easy to do without cutting a hole in the firewall. |
| Cairo94507 |
Jan 6 2025, 06:18 PM
Michael ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,609 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California
I agree 100% with Clay; the Clewett Serpentine Belt system is the one and done way to go. I have it on my 3.6 and can't imagine ever having a 6 in a 914 without it. My only regret is no one can see it; it is spectacular. (IMG:style_emoticons/default/beerchug.gif)
| worn |
Jan 6 2025, 07:08 PM
Winner of the Utah Twisted Joint Award ![]() ![]() ![]() ![]() Group: Members Posts: 3,560 Joined: 3-June 11 From: Madison, WI and North Bend WA Member No.: 13,152 Region Association: Upper MidWest
I’m getting closer to painting this 914 project. Is it worth making an access panel to the fan belt area of the engine? It’s a 3.2/6 if so how big should the hole be? Not enough fasteners. Like times four or five. Imagine the firewall being changed in shape. You want your hatch to change with it. And maintain a seal. My hatch is very helpful, but it is really battened down. |
| troth |
Jan 6 2025, 09:15 PM
Member ![]() ![]() Group: Members Posts: 160 Joined: 17-August 16 From: CT/WA Member No.: 20,305 Region Association: None |
Having snapped a couple belts in my 911 SC and knowing the type 2 fun of swapping a fan belt on a hot engine on the side of the road in the middle of nowhere in the dark...
I would like to hear the thoughts of those who have had to do this on a 914 (I am sure there are a few of you here) without the access panel. I have no problems dropping the engine for basic maintenance, it's more the roadside emergency situations that are tempting me to cut one in mine. |
| WFG |
Jan 7 2025, 05:57 AM
Member ![]() ![]() Group: Members Posts: 55 Joined: 6-December 05 From: nashville tenn 37076 Member No.: 5,243 |
I would not want to cut a hole in the firewall. just my opinion
| ClayPerrine |
Jan 7 2025, 06:13 AM
Having snapped a couple belts in my 911 SC and knowing the type 2 fun of swapping a fan belt on a hot engine on the side of the road in the middle of nowhere in the dark... I would like to hear the thoughts of those who have had to do this on a 914 (I am sure there are a few of you here) without the access panel. I have no problems dropping the engine for basic maintenance, it's more the roadside emergency situations that are tempting me to cut one in mine. On our factory six, which does not have an access panel, I had to change the belt on the side of the road shortly after getting it. I didn't try to reset the shims blindly, I just rolled on the new belt with a wrench. Once I got home, I dropped the motor and properly replaced the belt. Now every year it gets a new belt when I drop the motor to adjust valves and do maintenance. |
| Superhawk996 |
Jan 7 2025, 09:48 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,767 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
. . . it's more the roadside emergency situations that are tempting me to cut one in mine. So. . . You’re going to de-trim the interior roadside to get to the access panel? Or . . . You get to play street racer and drive around with no NVH treatments and no interior back pad. Noisy. Visible seat belt retractors, etc. Or . . . Go full on hillbilly and cut a hole in the backpad so you can get to the access panel. With a really good custom upholstery guy this might not be the duct tape abomination I’m envisioning. (IMG:style_emoticons/default/idea.gif) Am I missing options? The point being have you fully thought this through? |
| Steve |
Jan 7 2025, 10:54 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,028 Joined: 14-June 03 From: Laguna Niguel, CA Member No.: 822 Region Association: Southern California
I bought the PMS fiberglass panel. I only did this mod because at the time it seemed the only way to change the alternator in my 3.2, without dropping the engine. I now have a 3.6 and it does make getting to the distributor, etc. a lot easier. Here is the link to the PMS panel. However most people get an equivalent cover from a donor vehicle. If my car was a real six, I would not cut a hole in the firewall or anywhere else on the car which could lower the value of the car.
https://patrickmotorsports.com/products/bod...iYeRhO8pjowSAjV |
| Cairo94507 |
Jan 7 2025, 11:02 AM
On my second 914-6, back in the late 80's, we did an access panel when we put a 3.0 in it. Sourced a panel from a wrecked 914 and had about 3/4" overlap all around and used Dzus fasteners, 10 of them, to secure it with rubber weather stripping between the panel and the firewall. It was very secure and I felt it did not compromise the firewall. On my current 6, I would not cut the firewall. (IMG:style_emoticons/default/beerchug.gif)
| 930cabman |
Jan 7 2025, 12:00 PM
This poor horse
| BillJ |
Jan 7 2025, 01:40 PM
Mine has been there since 1984 so not my act but it is useful
| jfort |
Jan 7 2025, 02:42 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,188 Joined: 5-May 03 From: Findlay, OH Member No.: 652 Region Association: Upper MidWest
I have one in my modded factory six and in our Richie Ginter-type race car.
| mb911 |
Jan 8 2025, 03:32 PM
I’m getting closer to painting this 914 project. Is it worth making an access panel to the fan belt area of the engine? It’s a 3.2/6 if so how big should the hole be? no (IMG:style_emoticons/default/agree.gif) Having lived through an engine fire in a 914, I will not cut holes in anything called a "firewall". (IMG:style_emoticons/default/screwy.gif) If you have a 3.6, get a Clewett serpentine belt kit. It makes it a breeze to change the belt just by moving the tensioner. Here's a picture of it on my motor before I put it in. (IMG:http://www.914world.com/bbs2/uploads/post-1143-1475889671.jpg) Easy to do without cutting a hole in the firewall. This is the right answer. |
Lo-Fi Version | Time is now: 1st April 2026 - 11:17 PM |
