burton73 |
Senior member, and old dude ![]() ![]() ![]() ![]() Group: Members Posts: 3,868 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California ![]() ![]() |
@emerygt350
On to the great work that you are doing on the horn pucks. These pictures show the leather part as Dale contoured it for my 6 build. My factory old puck was less than flat same as @sixnotfour showed us. You can see how the leather has shrunk down as the padding material under the leather aged. If you could put the slight dome contour on your as well as the leather texture on it would be a fantastic item for people. I hope that you will come up with a way to monetize all your hard work! By the way I do not care what the Chalon hatters saw, I love the look of the Porsche 914 Chalon body, have from the late 1970. I had thought of doing one and putting the aluminum front and rear bumpers and real rubber accordion pieces from real 911s or 924 and Valances so it would not get damaged from scrapes in the real world. Just my thinking in the 80s Best Bob B ![]() |
emerygt350 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,068 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States ![]() |
Thanks for the images. I have created several leather textures but sadly 3d printing doesn't have the resolution to execute them. You can almost do it if you print it at an angle but that creates other issues.
The leather insert costs around 75 dollars I believe, perhaps I will make a version you could just insert that into. I do this for the challenge. It's like a crossword puzzle for me but I have something useful when I am done, and some improved skills with CAD. Long live the Chalon! |
sixnotfour |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,919 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains ![]() ![]() ![]() |
Ok, Snow melting,
The upper dia. is 99.00mm The step down at that dia. is 6.50mm The dia. just below above dia. is 102.50mm |
emerygt350 |
Great. I was very close. I guessed 7mm
sixnotfour |
old shrunk crest is 30mm x 37mm
The puck to the top of chrome is 2.5mm, and is 89.50 in dia. Width of chrome ring is 2.75mm |
emerygt350 |
Ok, quick update of the files today. I have now changed all of the measures to match what you guys have so thankfully provided. Looking pretty good. I am testing out the brass insert holes today (made them larger) and will start printing what I hope will be the final product. I kicked the little buttresses out to the 1.5 mm at the base. That was hard to do with the polar array in Blender. It really is like juggling twelve plates at the same time.
Here is the small logo version: ![]() And the large logo: ![]() And here is the print of yesterdays design before the last little changes today. I printed the small logo 'suspended' which allowed me to get a little better resolution on the logo. I rinsed it in acetone a couple times and then painted it. Didn't turn out too bad. You can see the brass inserts underneath. ![]() ![]() I am going to start printing the newest design and tomorrow I should have it all finished up! |
emerygt350 |
And these files are all updated on thingiverse if you want to give it a go.
https://www.thingiverse.com/thing:6238862 |
emerygt350 |
sixnotfour |
Very Nice !!!
sixnotfour |
Here's a pic of my vintage version.. (IMG:style_emoticons/default/beerchug.gif)
Attached image(s) ![]() |
emerygt350 |
Thanks! Next step is getting the chrome ring right...
rick 918-S |
Hey nice rack! -Celette ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 21,042 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region ![]() ![]() ![]() |
Very nice! I had a friend that did vinyl seat and dash repair several years ago. He would fill and apply some kind vinyl adhesibe and use multiple different vinyl patterns to press in the graining then mask and paint the dash or seat bolster to match. He would travel around to dealerships and do this. My point is, maybe the graining could be added in a similar manner.
emerygt350 |
I think something like that would work here. I am thinking about fillers...
rick 918-S |
Not that you need to replicate the exact look. It's cool that you have have the skills to do this.
emerygt350 |
sixnotfour |
burton73 |
Very nice, very nice!
emerygt350 |
emerygt350 |
yes, dia. of bumps... I can Get you any measurement you need,, later today.. @sixnotfour Can you send me the total height of the puck from base to the top of the chrome? |
sixnotfour |
yes, dia. of bumps... I can Get you any measurement you need,, later today.. @sixnotfour Can you send me the total height of the puck from base to the top of the chrome? About 31.25mm |
Lo-Fi Version | Time is now: 31st July 2025 - 05:52 PM |
