> 3.6L?
JimVG
post Feb 2 2025, 03:18 PM
Has anyone used a 89-98 911 3.6L case as the foundation for a 914 flat 6 build?
ClayPerrine
post Feb 2 2025, 05:38 PM
If you can, you are better off buying a complete core motor than trying to buy all the parts for an engine build individually. By the time you buy all the little nuts, bolts and screws, you spend way more money than you would if you just bought a used engine and rebuilt it.
Yes, 3.6 cases are available, but you have to have the crank, the rods the cylinders, the pistons, the heads, the cam carriers, the cam boxes the cams, the rocker arms, the intermediate shaft, the oil pump, the valve covers... the list goes on.
I got a relatively cheap 3.6 core that had an engine fire. Even then, I spent way too much getting all the fuel injection pieces to make it work.
Now I am selling all of that.
And with a 3.6, you have to alter the engine tin for it to fit. The 3.2 will fit with no alterations to the tin. I actually researched the idea of back dating the timing boxes on the 3.6 to use the 3.2 setup just so the engine tin would fit the front of the motor. And I looked at backdating the engine case to fit a engine mounted oil cooler too.
It was easier to fabricate engine tin to fit the 3.6.
I would suggest sitting down and making a pros and cons list of a 3.2 vs a 3.6 engine. Both are available out there used with all the fuel injection. And don't forget the 901 transmission is not really good with a 3.6 engine. Yes the 901 will work. But it is really not designed for the horsepower and torque of a 3.6.
I a
JimVG   3.6L?   Feb 2 2025, 03:18 PM
SirAndy   Many 3.6L 914s around these days. Some of which ha...   Feb 2 2025, 03:27 PM
JimVG   Thanks for that. My reason for asking is that I am...   Feb 2 2025, 03:39 PM
mepstein   Thanks for that. My reason for asking is that I a...   Feb 2 2025, 04:13 PM
ClayPerrine   If you can, you are better off buying a complete c...   Feb 2 2025, 05:38 PM
Steve   You can check out my recent build thread. I just ...   Feb 2 2025, 08:09 PM
JimVG   Thanks to all for this information. Is there anyo...   Feb 4 2025, 08:25 AM
technicalninja   You should also look at Subaru conversions. I...   Feb 4 2025, 02:43 PM
sb914   You should also look at Subaru conversions. I...   Feb 4 2025, 03:08 PM
JimVG   You should also look at Subaru conversions. I...   Feb 5 2025, 08:28 AM
ClayPerrine   [quote name='technicalninja' post='3190273' date=...   Feb 5 2025, 11:02 AM
technicalninja   Tygaboy cheated! He used a Ferrari transmissi...   Feb 4 2025, 03:19 PM
mb911   @mepstein always has 3.0 and 3.2 engines for sale   Feb 4 2025, 06:30 PM
Front yard mechanic   You could always put a1.8 porsche engine in it lik...   Feb 4 2025, 07:28 PM
mate914   You could always put a1.8 porsche engine in it li...   Feb 4 2025, 08:20 PM
rhodyguy   I would figure out if I wanted heat before I decid...   Feb 5 2025, 01:11 PM
technicalninja   I would figure out if I wanted heat before I deci...   Feb 5 2025, 01:21 PM
rhodyguy   Living in western WA I don’t worry about excessi...   Feb 5 2025, 01:36 PM
- Lo-Fi Version Time is now: 14th March 2026 - 10:28 AM
