| Retroracer |
Feb 3 2025, 09:02 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 655 Joined: 7-July 13 From: Bend OR Member No.: 16,100 Region Association: Pacific Northwest
| Justinp71 |
Feb 4 2025, 12:58 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,647 Joined: 11-October 04 From: Sacramento, CA Member No.: 2,922 Region Association: None
I feel your pain... I rebuilt my motor then spent the next few years chasing oil leaks that were mostly external. The breather hose was leaking, wouldn't seal until I bought a new hose, then had some oil leaking thru the studs on the cam towers, also the sump plate wanted to leak until I replaced it with an aluminum one, then had the drivers cam cover leak after about 8 years. Then had the oil cooler leak a little bit... car has been down the last year, I don't yet if it still has any leaks.
It is very reliable and a blast to drive, so there's that! |
Retroracer 914-6 GT tribute - engine drop Feb 3 2025, 09:02 PM
mepstein I’m surprised you would use a 5 blade fan. Feb 4 2025, 02:15 AM
rgalla9146 While in the neighborhood check the radial seal at... Feb 4 2025, 08:44 AM
Retroracer
While in the neighborhood check the radial seal a... Feb 4 2025, 10:11 AM
mlindner Did you have to pull the carbs for the drop Feb 4 2025, 10:48 AM
Retroracer
Yes... Feb 4 2025, 12:28 PM
tygaboy Hmmmm. He's able to work on his car while simu... Feb 4 2025, 12:06 PM
technicalninja
Hmmmm. He's able to work on his car while sim... Feb 4 2025, 06:26 PM![]() ![]() |
Lo-Fi Version | Time is now: 16th April 2026 - 05:12 PM |
