| Retroracer |
Feb 3 2025, 09:02 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 655 Joined: 7-July 13 From: Bend OR Member No.: 16,100 Region Association: Pacific Northwest
| rgalla9146 |
Feb 4 2025, 08:44 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,959 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None
While in the neighborhood check the radial seal at the pulley and ... the (IMG:style_emoticons/default/sad.gif) O ring on the # 8 crank bearing.
( Tony is that my old fiberglass 'tin' ? ) |
| Retroracer |
Feb 4 2025, 10:11 AM
While in the neighborhood check the radial seal at the pulley and ... the (IMG:style_emoticons/default/sad.gif) O ring on the # 8 crank bearing. ( Tony is that my old fiberglass 'tin' ? ) Yes it is! The various pieces needed some fettling to fit, but works well and looks fantastic. Very happy with the purchase. And, appreciate the pointers to check out for leaks. I suspected the main pulley seal - but that seems dry and intact. Next culprit may be the IMS cover plate - but need to go slow and be sure; I don't want to have to do this again too soon. @mepstein Your surprise is duly noted. - Tony |
Retroracer 914-6 GT tribute - engine drop Feb 3 2025, 09:02 PM
Justinp71 I feel your pain... I rebuilt my motor then spent ... Feb 4 2025, 12:58 AM
mepstein I’m surprised you would use a 5 blade fan. Feb 4 2025, 02:15 AM
mlindner Did you have to pull the carbs for the drop Feb 4 2025, 10:48 AM
Retroracer
Yes... Feb 4 2025, 12:28 PM
tygaboy Hmmmm. He's able to work on his car while simu... Feb 4 2025, 12:06 PM
technicalninja
Hmmmm. He's able to work on his car while sim... Feb 4 2025, 06:26 PM![]() ![]() |
Lo-Fi Version | Time is now: 10th May 2026 - 05:11 PM |
