| Retroracer |
Feb 3 2025, 09:02 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 649 Joined: 7-July 13 From: Bend OR Member No.: 16,100 Region Association: Pacific Northwest
| mlindner |
Feb 4 2025, 10:48 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,718 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest
Did you have to pull the carbs for the drop
| Retroracer |
Feb 4 2025, 12:28 PM
Did you have to pull the carbs for the drop Yes; with the combo of the transmission jack I have and the angle of the bodyshell, taking the carbs off was going to be easier. Also, being a GT clone, no rear valance to remove - which helps. Luckily the cooling fan housing / coil cleared OK and could be left attached. - Tony |
Retroracer 914-6 GT tribute - engine drop Feb 3 2025, 09:02 PM
Justinp71 I feel your pain... I rebuilt my motor then spent ... Feb 4 2025, 12:58 AM
mepstein I’m surprised you would use a 5 blade fan. Feb 4 2025, 02:15 AM
rgalla9146 While in the neighborhood check the radial seal at... Feb 4 2025, 08:44 AM
Retroracer
While in the neighborhood check the radial seal a... Feb 4 2025, 10:11 AM
tygaboy Hmmmm. He's able to work on his car while simu... Feb 4 2025, 12:06 PM
technicalninja
Hmmmm. He's able to work on his car while sim... Feb 4 2025, 06:26 PM![]() ![]() |
Lo-Fi Version | Time is now: 13th December 2025 - 07:19 AM |
