> Why, oh Why Wipers!, Pull wiper motor without removing gas tank?
PDXBob
post Feb 3 2025, 10:02 PM
I’m pretty sure I know the answer, but hoping I’m wrong. My wiper motor is operating very, very slowly. I’ve cleaned the arms and all joints but no improvement. So, my question is: can you remove the wiper motor without taking out the gas tank? Car is a 1975 914, I’ve had tank out once, just a lot of work.
Thx,
PDXBob
ClayPerrine
post Feb 5 2025, 12:28 PM
Another common cause of slow wipers is the shafts getting corroded where they come up through the cowl. When you pull the wiper assembly, take the shafts out of the frame, then clean them up and lube them.
Water stands in the dimples where the shafts come through the cowl, and it gets down in between the shaft and the frame, rusting the shaft. Then they run slow due to excessive friction.
Happens to the 911 guys too. But not quite as bad.
- Lo-Fi Version Time is now: 6th February 2026 - 12:52 PM
