| PDXBob |
Feb 3 2025, 10:02 PM
Member ![]() ![]() Group: Members Posts: 61 Joined: 16-May 20 From: Portland Oregon Member No.: 24,272 Region Association: Pacific Northwest
I’m pretty sure I know the answer, but hoping I’m wrong. My wiper motor is operating very, very slowly. I’ve cleaned the arms and all joints but no improvement. So, my question is: can you remove the wiper motor without taking out the gas tank? Car is a 1975 914, I’ve had tank out once, just a lot of work.
Thx, PDXBob |
| VaccaRabite |
Feb 8 2025, 09:06 AM
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,837 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region
Short answer - do anything you can to avoid pulling the wipers.
But if you DO pull the wipers, plan on doing a lot of other maintenance while you have all that other stuff out of the car. Like the under tank fuel lines, moving the pump under the tank if you have an early car, replacing the filter if you have a later car. To avoid pulling stuff out, clean your grounds as stated. And also spray lithium grease down the shafts. Wiggle them around, however you can get it in there. Pulling the tank out isn't that bad of a job. Getting the airbox out SUCKS. Zach |
PDXBob Why, oh Why Wipers! Feb 3 2025, 10:02 PM
L-Jet914 According to the FSM directions say to remove tank... Feb 3 2025, 11:48 PM
mepstein Removing the fuel tank is the easiest part of that... Feb 4 2025, 02:16 AM
ConeDodger Ground. Feb 4 2025, 06:26 AM
PDXBob
Ground.
Found ??? Feb 4 2025, 03:01 PM
fiacra
Ground.
Found ???
To put it in long form: y... Feb 4 2025, 06:21 PM
ConeDodger
[quote name='PDXBob' post='3190278' date='Feb 4 2... Feb 4 2025, 09:58 PM
ClayPerrine Another common cause of slow wipers is the shafts ... Feb 5 2025, 12:28 PM
Eric_Shea When (if) you get there... make sure you remove th... Feb 5 2025, 06:30 PM
914werke Another common cause of slow wipers is the shafts... Feb 8 2025, 11:31 AM![]() ![]() |
Lo-Fi Version | Time is now: 18th January 2026 - 02:09 PM |
