> 70-914-6 Clean Up, Carbs and Starting - QUESTIONS
ctc911ctc
post Feb 4 2025, 09:19 AM
1970, 914-6, 93K miles - excellent shape, very minor rust
I will post to this thread occasionally as I move through this project, I have asked for guidance and received many good thoughts from this team - thank you 914World
I am in the midst of removing the engine and transmission. All original. There is oil everywhere, not flowing but seeping - seems that the valve covers are not tightened or have loosened with age. Here are the first pics:
On the rack - hopefully not for long:
Shift Assembly is very clean, no wear, bushings are in good shape but all of them will be replaced
Heat exchangers have no holes in the pipes that I could find, the surrounding tin has been treated with anti-rust leakage - perhaps this was the plan in Stuttgart?
No plans to change the exhaust system - any guidance as to cleaning or preservation?
All comments and guidance appreciated - engine coming down on Friday
Superhawk996
post Feb 23 2025, 11:30 AM
FWIW I have the same tool issue. Bought from someone used actually marked P225; represented as a P225; but it clearly isn’t. They are out there floating around.
Please share vendor so that others don’t run into the same issue.
ctc911ctc
post Feb 23 2025, 12:00 PM
Super Hawk,
Perhaps I am a bit naive, however, I believe that these are honest mistakes (perhaps not in your case) as a result of their being no MODEL STAMP on the tool, the 225 and the 226 are the same with a small (frustrating) variation
I have sent a note to Sir Tools with this suggestion....we shall see......
Depending on the response on Monday I will post more..,... (IMG:style_emoticons/default/dry.gif)
QUOTE(Superhawk996 @ Feb 23 2025, 12:30 PM) *
ctc911ctc   70-914-6 Clean Up   Feb 4 2025, 09:19 AM
DennisV   1970, 914-6, 93K miles - excellent shape, very mi...   Feb 4 2025, 09:37 AM
ctc911ctc   Great minds.................. :D It arrives on F...   Feb 4 2025, 10:59 AM
DennisV   Great minds.................. :D It arrives on ...   Feb 4 2025, 02:22 PM
mb911   1970, 914-6, 93K miles - excellent shape, very mi...   Feb 4 2025, 11:17 AM
ctc911ctc   powder coat? I have refurbished many original ...   Feb 4 2025, 11:29 AM
Cairo94507   If you are interested in doing more than Ben sugge...   Feb 4 2025, 02:51 PM
ctc911ctc   I found a very good powder coat shop here in the B...   Feb 4 2025, 03:19 PM
ClayPerrine   On our 70 914-6, the DAPO had the heat exchangers ...   Feb 5 2025, 07:25 AM
ctc911ctc   I have a set of the stainless fuel line ready to g...   Feb 5 2025, 08:43 AM
Rusty   On our 70 914-6, the DAPO had the heat exchangers...   Feb 5 2025, 03:40 PM
ClayPerrine   On our 70 914-6, the DAPO had the heat exchanger...   Feb 5 2025, 03:42 PM
barefoot   On our 70 914-6, the DAPO had the heat exchangers...   Feb 24 2025, 08:02 AM
ctc911ctc   I may be alone in this thought, however, looking a...   Feb 24 2025, 08:12 AM
ctc911ctc   Drained the transmission last night, when I rolled...   Feb 5 2025, 08:47 AM
Root_Werks   Sure looks like a clean 914-6, can't wait to s...   Feb 5 2025, 11:41 AM
930cabman   Looks like a great example :beer2:   Feb 5 2025, 01:12 PM
technicalninja   Drained the transmission last night, when I rolle...   Feb 5 2025, 01:41 PM
ctc911ctc   Drained the transmission last night, when I roll...   Feb 5 2025, 03:22 PM
technicalninja   [quote name='technicalninja' post='3190434' date=...   Feb 5 2025, 04:12 PM
ctc911ctc   Found a 901 Core in CT yesterday, drove and picked...   Feb 6 2025, 08:53 PM
rgalla9146   Your impression of the internals is good ? put...   Feb 6 2025, 09:14 PM
ctc911ctc   Rory, I will crack the 914-6 case this weekend, pr...   Feb 6 2025, 09:20 PM
ClayPerrine   Rory, I will crack the 914-6 case this weekend, p...   Feb 7 2025, 03:41 PM
ctc911ctc   Clay, Thanks for the note! I would not change...   Feb 7 2025, 09:01 PM
worn   I learned this the hard way. When I first had my...   Feb 18 2025, 09:06 PM
rgalla9146   I have a rear shift 4 cyl. trans (with ZF ltd.slip...   Feb 7 2025, 04:39 PM
ctc911ctc   *********UPDATE*********** Drained all of the fl...   Feb 9 2025, 03:17 PM
ctc911ctc   ******UPDATE******* Dropped the engine, all the w...   Feb 16 2025, 03:04 PM
rgalla9146   Cary Those are not cracks. They are shadows ...   Feb 16 2025, 05:51 PM
ctc911ctc   Hey Rory, Yes, I have the transmission apart and ...   Feb 16 2025, 07:50 PM
HaraldD   Hello, if you want to look for cracks, you have t...   Feb 17 2025, 07:31 AM
rgalla9146   Hello, if you want to look for cracks, you have ...   Feb 17 2025, 10:52 AM
ctc911ctc   Two transmissions open, the core is as good as the...   Feb 18 2025, 02:15 PM
ctc911ctc   ******UPDATE****** DOG TEETH Removal Stalled anot...   Feb 23 2025, 11:04 AM
Superhawk996   FWIW I have the same tool issue. Bought from some...   Feb 23 2025, 11:30 AM
ctc911ctc   Super Hawk, Perhaps I am a bit naive, however, I ...   Feb 23 2025, 12:00 PM
Superhawk996   Super Hawk, Perhaps I am a bit naive, however, I...   Feb 23 2025, 12:28 PM
ctc911ctc   Agreed - my next target is an 84-86 911-SC, could ...   Feb 23 2025, 04:39 PM
ctc911ctc   Afternoon Update Got the carbs off which allowed ...   Feb 23 2025, 04:48 PM
ctc911ctc   **********Afternoon Work Continued*********** Got...   Feb 23 2025, 04:52 PM
DennisV   Cleaning the "Flap Control Boxes" used ...   Feb 24 2025, 08:53 AM
ctc911ctc   The flappers are in really good shape - both sprin...   Feb 24 2025, 08:58 AM
Superhawk996   Is starter one of the gear reduction / Denso types...   Feb 23 2025, 07:51 PM
ctc911ctc   I do not think so - I do not see anything other th...   Feb 23 2025, 08:31 PM
rgalla9146   I do not think so - I do not see anything other t...   Feb 24 2025, 10:32 AM
ctc911ctc   As always Rory has great advice - Thank you Rory -...   Feb 24 2025, 10:48 AM
ctc911ctc   Spent a few hours this morning traveling to get a ...   Mar 1 2025, 04:59 PM
ctc911ctc   Engine on Stand - Tetris with Blocks lift and pati...   Mar 4 2025, 07:03 AM
ctc911ctc   ********UPDATE********* Heater Manifolds and all ...   Mar 5 2025, 01:55 PM
Root_Werks   Lucky enough to also have a good powder coater clo...   Mar 5 2025, 03:03 PM
ctc911ctc   Took the valve covers off, they were close to fing...   Mar 6 2025, 07:33 PM
mepstein   Are you doing a leak down on the heads?   Mar 6 2025, 09:18 PM
ctc911ctc   The compression is good and ran strong, I was most...   Mar 9 2025, 08:12 PM
ctc911ctc   just bought a leak-down tool - will let you know...   Mar 10 2025, 11:17 AM
ctc911ctc   Still cleaning the engine - took off the flywheel ...   Mar 10 2025, 11:15 AM
ctc911ctc   Lots of progress getting rid of the grease and dir...   Mar 10 2025, 07:43 PM
fixer34   Stock lower valve covers were notorious for warpin...   Mar 10 2025, 08:16 PM
930cabman   Stock lower valve covers were notorious for warpi...   Mar 11 2025, 04:42 PM
ctc911ctc   On my small machinist table they are straight - I ...   Mar 11 2025, 06:36 PM
ctc911ctc   Today Did the leak down test, only could do one si...   Mar 11 2025, 06:44 PM
ctc911ctc   ******UPDATE******* Transmission parts arrived he...   Mar 31 2025, 08:26 AM
ctc911ctc   ****UPDATE***** Pulley Seal came, time to remove...   Apr 1 2025, 07:16 PM
Luke M   You will want to replace the ims cover gasket. The...   Apr 2 2025, 05:13 AM
ctc911ctc   Yes, I have this covered, working on flattening th...   Apr 2 2025, 10:58 AM
ctc911ctc   *******UPDATE******* I pulled the plugs and perfo...   Apr 11 2025, 11:06 AM
ctc911ctc   *******UPDATE******* I pulled the plugs and perf...   Apr 11 2025, 11:09 AM
rgalla9146   Very stout numbers for an engine that has been bas...   Apr 11 2025, 01:16 PM
ctc911ctc   This weekend I have been prepping to put things ba...   Apr 14 2025, 11:39 AM
ctc911ctc   Before and After The Magnesium is pitted but cle...   Apr 26 2025, 03:55 PM
ctc911ctc   Wiring and Shroud today here are a few pictures ...   Apr 26 2025, 04:01 PM
ctc911ctc   I went to the hardware store and purchased some su...   Apr 26 2025, 04:05 PM
porschetub   I went to the hardware store and purchased some s...   Apr 26 2025, 05:57 PM
ctc911ctc   I am glad you asked - I used the existing ground s...   Apr 26 2025, 06:41 PM
porschetub   I am glad you asked - I used the existing ground ...   Apr 27 2025, 01:39 PM
ctc911ctc   I am glad you asked - I used the existing ground...   Apr 27 2025, 08:35 PM
rgalla9146   The ground strap attaches to the case just to the ...   Apr 27 2025, 06:55 AM
ctc911ctc   Distributor I really like this setup, simple, no ...   May 3 2025, 02:50 PM
mb911   Where is there a rebuild kit available? I remember...   May 3 2025, 05:09 PM
ctc911ctc   https://www.partsklassik.com/p-3794-distrib...mare...   May 3 2025, 08:06 PM
ctc911ctc   Here is what I am trying to fix - all of this old ...   May 3 2025, 08:11 PM
Cairo94507   It may not be the same, but when we replaced the b...   May 4 2025, 06:23 AM
ctc911ctc   Engine Ready for the tin, looking better, Movi...   May 23 2025, 08:08 AM
ctc911ctc   *******UPDATE********* Cleaning up the engine, ...   Jul 7 2025, 11:19 AM
Cairo94507   That may be undercoating applied when new. Mine h...   Jul 7 2025, 12:51 PM
ctc911ctc   Tooth Brush and Brake cleaner......... <_< ...   Jul 7 2025, 01:06 PM
ctc911ctc   What did you use for the blasting? That may be ...   Jul 7 2025, 01:38 PM
Cairo94507   It was sandblasting and scraper.   Jul 7 2025, 05:15 PM
sixnotfour   Dry Ice Blasting ..I saw this Six at Morris Brothe...   Jul 7 2025, 05:27 PM
gereed75   Love this kind of preservation/ restoration. Gre...   Jul 7 2025, 06:31 PM
BillJ   I am a huge fan of dry ice blasting. Did the whole...   Jul 7 2025, 07:01 PM
930cabman   I am a huge fan of dry ice blasting. Did the whol...   Jul 17 2025, 06:34 AM
ctc911ctc   OK, Dry ice it is.........last time I bought dry i...   Jul 7 2025, 07:40 PM
live free & drive   You can get the pellets at Continental Carbonic an...   Jul 9 2025, 02:32 PM
ctc911ctc   Cleaning the underside of the lid, dang the old oi...   Jul 13 2025, 07:40 PM
ctc911ctc   *********UPDATE******** ICE ICE BABY I spent 20+...   Jul 22 2025, 07:17 PM
ctc911ctc   Back from the ICE house, good kid, hard working - ...   Aug 11 2025, 07:07 PM
ctc911ctc   On its way home through Boston Traffic...   Aug 11 2025, 07:10 PM
Montreal914   This seems like the way to go. Looking very good...   Aug 11 2025, 08:37 PM
ctc911ctc   ********FUEL LINES*********** Took out the Tank -...   Aug 20 2025, 12:54 PM
- Lo-Fi Version Time is now: 11th February 2026 - 07:21 PM
