> 70-914-6 Clean Up, Carbs and Starting - QUESTIONS
ctc911ctc
post Feb 4 2025, 09:19 AM
1970, 914-6, 93K miles - excellent shape, very minor rust
I will post to this thread occasionally as I move through this project, I have asked for guidance and received many good thoughts from this team - thank you 914World
I am in the midst of removing the engine and transmission. All original. There is oil everywhere, not flowing but seeping - seems that the valve covers are not tightened or have loosened with age. Here are the first pics:
On the rack - hopefully not for long:
Shift Assembly is very clean, no wear, bushings are in good shape but all of them will be replaced
Heat exchangers have no holes in the pipes that I could find, the surrounding tin has been treated with anti-rust leakage - perhaps this was the plan in Stuttgart?
No plans to change the exhaust system - any guidance as to cleaning or preservation?
All comments and guidance appreciated - engine coming down on Friday
Superhawk996
post Feb 23 2025, 11:30 AM
FWIW I have the same tool issue. Bought from someone used actually marked P225; represented as a P225; but it clearly isn’t. They are out there floating around.
Please share vendor so that others don’t run into the same issue.
ctc911ctc
post Feb 23 2025, 12:00 PM
Super Hawk,
Perhaps I am a bit naive, however, I believe that these are honest mistakes (perhaps not in your case) as a result of their being no MODEL STAMP on the tool, the 225 and the 226 are the same with a small (frustrating) variation
I have sent a note to Sir Tools with this suggestion....we shall see......
Depending on the response on Monday I will post more..,... (IMG:style_emoticons/default/dry.gif)
QUOTE(Superhawk996 @ Feb 23 2025, 12:30 PM) *
Superhawk996
post Feb 23 2025, 12:28 PM
QUOTE(ctc911ctc @ Feb 23 2025, 02:00 PM) *
Super Hawk,
Understood.
I’ll bet they will make it right. I don’t view the vendor sharing as a slam on them. Just a good heads up to others so they know the issue is occurring and to verify what they received right away vs putting it on a shelf and then falling outside a traditional return period.
In my case, I suspect it was a manufacturing error and whoever I bought it from sold it in good faith as I bought it as part of a bigger lot of trans tools.
Strange how P225 tools have been out of stock for years. Not sure what is going on there.
In my case, I’ll either modify the tool when I get my machine tools back up and running or I’ll save it for someday when I get a 915 transmission (IMG:style_emoticons/default/av-943.gif)
ctc911ctc   70-914-6 Clean Up   Feb 4 2025, 09:19 AM
DennisV   1970, 914-6, 93K miles - excellent shape, very mi...   Feb 4 2025, 09:37 AM
ctc911ctc   Great minds.................. :D It arrives on F...   Feb 4 2025, 10:59 AM
DennisV   Great minds.................. :D It arrives on ...   Feb 4 2025, 02:22 PM
mb911   1970, 914-6, 93K miles - excellent shape, very mi...   Feb 4 2025, 11:17 AM
ctc911ctc   powder coat? I have refurbished many original ...   Feb 4 2025, 11:29 AM
Cairo94507   If you are interested in doing more than Ben sugge...   Feb 4 2025, 02:51 PM
ctc911ctc   I found a very good powder coat shop here in the B...   Feb 4 2025, 03:19 PM
ClayPerrine   On our 70 914-6, the DAPO had the heat exchangers ...   Feb 5 2025, 07:25 AM
ctc911ctc   I have a set of the stainless fuel line ready to g...   Feb 5 2025, 08:43 AM
Rusty   On our 70 914-6, the DAPO had the heat exchangers...   Feb 5 2025, 03:40 PM
ClayPerrine   On our 70 914-6, the DAPO had the heat exchanger...   Feb 5 2025, 03:42 PM
barefoot   On our 70 914-6, the DAPO had the heat exchangers...   Feb 24 2025, 08:02 AM
ctc911ctc   I may be alone in this thought, however, looking a...   Feb 24 2025, 08:12 AM
ctc911ctc   Drained the transmission last night, when I rolled...   Feb 5 2025, 08:47 AM
Root_Werks   Sure looks like a clean 914-6, can't wait to s...   Feb 5 2025, 11:41 AM
930cabman   Looks like a great example :beer2:   Feb 5 2025, 01:12 PM
technicalninja   Drained the transmission last night, when I rolle...   Feb 5 2025, 01:41 PM
ctc911ctc   Drained the transmission last night, when I roll...   Feb 5 2025, 03:22 PM
technicalninja   [quote name='technicalninja' post='3190434' date=...   Feb 5 2025, 04:12 PM
ctc911ctc   Found a 901 Core in CT yesterday, drove and picked...   Feb 6 2025, 08:53 PM
rgalla9146   Your impression of the internals is good ? put...   Feb 6 2025, 09:14 PM
ctc911ctc   Rory, I will crack the 914-6 case this weekend, pr...   Feb 6 2025, 09:20 PM
ClayPerrine   Rory, I will crack the 914-6 case this weekend, p...   Feb 7 2025, 03:41 PM
ctc911ctc   Clay, Thanks for the note! I would not change...   Feb 7 2025, 09:01 PM
worn   I learned this the hard way. When I first had my...   Feb 18 2025, 09:06 PM
rgalla9146   I have a rear shift 4 cyl. trans (with ZF ltd.slip...   Feb 7 2025, 04:39 PM
ctc911ctc   *********UPDATE*********** Drained all of the fl...   Feb 9 2025, 03:17 PM
ctc911ctc   ******UPDATE******* Dropped the engine, all the w...   Feb 16 2025, 03:04 PM
rgalla9146   Cary Those are not cracks. They are shadows ...   Feb 16 2025, 05:51 PM
ctc911ctc   Hey Rory, Yes, I have the transmission apart and ...   Feb 16 2025, 07:50 PM
HaraldD   Hello, if you want to look for cracks, you have t...   Feb 17 2025, 07:31 AM
rgalla9146   Hello, if you want to look for cracks, you have ...   Feb 17 2025, 10:52 AM
ctc911ctc   Two transmissions open, the core is as good as the...   Feb 18 2025, 02:15 PM
ctc911ctc   ******UPDATE****** DOG TEETH Removal Stalled anot...   Feb 23 2025, 11:04 AM
Superhawk996   FWIW I have the same tool issue. Bought from some...   Feb 23 2025, 11:30 AM
ctc911ctc   Super Hawk, Perhaps I am a bit naive, however, I ...   Feb 23 2025, 12:00 PM
Superhawk996   Super Hawk, Perhaps I am a bit naive, however, I...   Feb 23 2025, 12:28 PM
ctc911ctc   Agreed - my next target is an 84-86 911-SC, could ...   Feb 23 2025, 04:39 PM
ctc911ctc   Afternoon Update Got the carbs off which allowed ...   Feb 23 2025, 04:48 PM
ctc911ctc   **********Afternoon Work Continued*********** Got...   Feb 23 2025, 04:52 PM
DennisV   Cleaning the "Flap Control Boxes" used ...   Feb 24 2025, 08:53 AM
ctc911ctc   The flappers are in really good shape - both sprin...   Feb 24 2025, 08:58 AM
Superhawk996   Is starter one of the gear reduction / Denso types...   Feb 23 2025, 07:51 PM
ctc911ctc   I do not think so - I do not see anything other th...   Feb 23 2025, 08:31 PM
rgalla9146   I do not think so - I do not see anything other t...   Feb 24 2025, 10:32 AM
ctc911ctc   As always Rory has great advice - Thank you Rory -...   Feb 24 2025, 10:48 AM
ctc911ctc   Spent a few hours this morning traveling to get a ...   Mar 1 2025, 04:59 PM
ctc911ctc   Engine on Stand - Tetris with Blocks lift and pati...   Mar 4 2025, 07:03 AM
ctc911ctc   ********UPDATE********* Heater Manifolds and all ...   Mar 5 2025, 01:55 PM
Root_Werks   Lucky enough to also have a good powder coater clo...   Mar 5 2025, 03:03 PM
ctc911ctc   Took the valve covers off, they were close to fing...   Mar 6 2025, 07:33 PM
mepstein   Are you doing a leak down on the heads?   Mar 6 2025, 09:18 PM
ctc911ctc   The compression is good and ran strong, I was most...   Mar 9 2025, 08:12 PM
ctc911ctc   just bought a leak-down tool - will let you know...   Mar 10 2025, 11:17 AM
ctc911ctc   Still cleaning the engine - took off the flywheel ...   Mar 10 2025, 11:15 AM
ctc911ctc   Lots of progress getting rid of the grease and dir...   Mar 10 2025, 07:43 PM
fixer34   Stock lower valve covers were notorious for warpin...   Mar 10 2025, 08:16 PM
930cabman   Stock lower valve covers were notorious for warpi...   Mar 11 2025, 04:42 PM
ctc911ctc   On my small machinist table they are straight - I ...   Mar 11 2025, 06:36 PM
ctc911ctc   Today Did the leak down test, only could do one si...   Mar 11 2025, 06:44 PM
ctc911ctc   ******UPDATE******* Transmission parts arrived he...   Mar 31 2025, 08:26 AM
ctc911ctc   ****UPDATE***** Pulley Seal came, time to remove...   Apr 1 2025, 07:16 PM
Luke M   You will want to replace the ims cover gasket. The...   Apr 2 2025, 05:13 AM
ctc911ctc   Yes, I have this covered, working on flattening th...   Apr 2 2025, 10:58 AM
ctc911ctc   *******UPDATE******* I pulled the plugs and perfo...   Apr 11 2025, 11:06 AM
ctc911ctc   *******UPDATE******* I pulled the plugs and perf...   Apr 11 2025, 11:09 AM
rgalla9146   Very stout numbers for an engine that has been bas...   Apr 11 2025, 01:16 PM
ctc911ctc   This weekend I have been prepping to put things ba...   Apr 14 2025, 11:39 AM
ctc911ctc   Before and After The Magnesium is pitted but cle...   Apr 26 2025, 03:55 PM
ctc911ctc   Wiring and Shroud today here are a few pictures ...   Apr 26 2025, 04:01 PM
ctc911ctc   I went to the hardware store and purchased some su...   Apr 26 2025, 04:05 PM
porschetub   I went to the hardware store and purchased some s...   Apr 26 2025, 05:57 PM
ctc911ctc   I am glad you asked - I used the existing ground s...   Apr 26 2025, 06:41 PM
porschetub   I am glad you asked - I used the existing ground ...   Apr 27 2025, 01:39 PM
ctc911ctc   I am glad you asked - I used the existing ground...   Apr 27 2025, 08:35 PM
rgalla9146   The ground strap attaches to the case just to the ...   Apr 27 2025, 06:55 AM
ctc911ctc   Distributor I really like this setup, simple, no ...   May 3 2025, 02:50 PM
mb911   Where is there a rebuild kit available? I remember...   May 3 2025, 05:09 PM
ctc911ctc   https://www.partsklassik.com/p-3794-distrib...mare...   May 3 2025, 08:06 PM
ctc911ctc   Here is what I am trying to fix - all of this old ...   May 3 2025, 08:11 PM
Cairo94507   It may not be the same, but when we replaced the b...   May 4 2025, 06:23 AM
ctc911ctc   Engine Ready for the tin, looking better, Movi...   May 23 2025, 08:08 AM
ctc911ctc   *******UPDATE********* Cleaning up the engine, ...   Jul 7 2025, 11:19 AM
Cairo94507   That may be undercoating applied when new. Mine h...   Jul 7 2025, 12:51 PM
ctc911ctc   Tooth Brush and Brake cleaner......... <_< ...   Jul 7 2025, 01:06 PM
ctc911ctc   What did you use for the blasting? That may be ...   Jul 7 2025, 01:38 PM
Cairo94507   It was sandblasting and scraper.   Jul 7 2025, 05:15 PM
sixnotfour   Dry Ice Blasting ..I saw this Six at Morris Brothe...   Jul 7 2025, 05:27 PM
gereed75   Love this kind of preservation/ restoration. Gre...   Jul 7 2025, 06:31 PM
BillJ   I am a huge fan of dry ice blasting. Did the whole...   Jul 7 2025, 07:01 PM
930cabman   I am a huge fan of dry ice blasting. Did the whol...   Jul 17 2025, 06:34 AM
ctc911ctc   OK, Dry ice it is.........last time I bought dry i...   Jul 7 2025, 07:40 PM
live free & drive   You can get the pellets at Continental Carbonic an...   Jul 9 2025, 02:32 PM
ctc911ctc   Cleaning the underside of the lid, dang the old oi...   Jul 13 2025, 07:40 PM
ctc911ctc   *********UPDATE******** ICE ICE BABY I spent 20+...   Jul 22 2025, 07:17 PM
ctc911ctc   Back from the ICE house, good kid, hard working - ...   Aug 11 2025, 07:07 PM
ctc911ctc   On its way home through Boston Traffic...   Aug 11 2025, 07:10 PM
Montreal914   This seems like the way to go. Looking very good...   Aug 11 2025, 08:37 PM
ctc911ctc   ********FUEL LINES*********** Took out the Tank -...   Aug 20 2025, 12:54 PM
- Lo-Fi Version Time is now: 12th February 2026 - 12:33 AM
