| ctc911ctc |
Feb 4 2025, 09:19 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,316 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States
1970, 914-6, 93K miles - excellent shape, very minor rust
I will post to this thread occasionally as I move through this project, I have asked for guidance and received many good thoughts from this team - thank you 914World I am in the midst of removing the engine and transmission. All original. There is oil everywhere, not flowing but seeping - seems that the valve covers are not tightened or have loosened with age. Here are the first pics: On the rack - hopefully not for long: ![]() Shift Assembly is very clean, no wear, bushings are in good shape but all of them will be replaced ![]() ![]() ![]() Heat exchangers have no holes in the pipes that I could find, the surrounding tin has been treated with anti-rust leakage - perhaps this was the plan in Stuttgart? ![]() ![]() ![]() No plans to change the exhaust system - any guidance as to cleaning or preservation? All comments and guidance appreciated - engine coming down on Friday |
| mepstein |
Mar 6 2025, 09:18 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,538 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
Are you doing a leak down on the heads?
| ctc911ctc |
Mar 10 2025, 11:17 AM
ctc911ctc 70-914-6 Clean Up Feb 4 2025, 09:19 AM
DennisV
1970, 914-6, 93K miles - excellent shape, very mi... Feb 4 2025, 09:37 AM
ctc911ctc Great minds.................. :D
It arrives on F... Feb 4 2025, 10:59 AM
DennisV
It arrives on ... Feb 4 2025, 02:22 PM
mb911
1970, 914-6, 93K miles - excellent shape, very mi... Feb 4 2025, 11:17 AM
ctc911ctc powder coat?
I have refurbished many original ... Feb 4 2025, 11:29 AM
Cairo94507 If you are interested in doing more than Ben sugge... Feb 4 2025, 02:51 PM
ctc911ctc I found a very good powder coat shop here in the B... Feb 4 2025, 03:19 PM
ClayPerrine On our 70 914-6, the DAPO had the heat exchangers ... Feb 5 2025, 07:25 AM
ctc911ctc I have a set of the stainless fuel line ready to g... Feb 5 2025, 08:43 AM
Rusty
On our 70 914-6, the DAPO had the heat exchangers... Feb 5 2025, 03:40 PM
ClayPerrine
On our 70 914-6, the DAPO had the heat exchanger... Feb 5 2025, 03:42 PM
barefoot
On our 70 914-6, the DAPO had the heat exchangers... Feb 24 2025, 08:02 AM
ctc911ctc I may be alone in this thought, however, looking a... Feb 24 2025, 08:12 AM
ctc911ctc Drained the transmission last night, when I rolled... Feb 5 2025, 08:47 AM
Root_Werks Sure looks like a clean 914-6, can't wait to s... Feb 5 2025, 11:41 AM
930cabman Looks like a great example
:beer2: Feb 5 2025, 01:12 PM
technicalninja
Drained the transmission last night, when I rolle... Feb 5 2025, 01:41 PM
ctc911ctc
Drained the transmission last night, when I roll... Feb 5 2025, 03:22 PM
technicalninja
[quote name='technicalninja' post='3190434' date=... Feb 5 2025, 04:12 PM
ctc911ctc Found a 901 Core in CT yesterday, drove and picked... Feb 6 2025, 08:53 PM
rgalla9146 Your impression of the internals is good ?
put... Feb 6 2025, 09:14 PM
ctc911ctc Rory, I will crack the 914-6 case this weekend, pr... Feb 6 2025, 09:20 PM
ClayPerrine
Rory, I will crack the 914-6 case this weekend, p... Feb 7 2025, 03:41 PM
ctc911ctc Clay,
Thanks for the note! I would not change... Feb 7 2025, 09:01 PM
worn
I learned this the hard way. When I first had my... Feb 18 2025, 09:06 PM
rgalla9146 I have a rear shift 4 cyl. trans (with ZF ltd.slip... Feb 7 2025, 04:39 PM
ctc911ctc *********UPDATE***********
Drained all of the fl... Feb 9 2025, 03:17 PM
ctc911ctc ******UPDATE*******
Dropped the engine, all the w... Feb 16 2025, 03:04 PM
rgalla9146 Cary
Those are not cracks. They are shadows ... Feb 16 2025, 05:51 PM
ctc911ctc Hey Rory,
Yes, I have the transmission apart and ... Feb 16 2025, 07:50 PM
HaraldD Hello,
if you want to look for cracks, you have t... Feb 17 2025, 07:31 AM
rgalla9146
Hello,
if you want to look for cracks, you have ... Feb 17 2025, 10:52 AM
ctc911ctc Two transmissions open, the core is as good as the... Feb 18 2025, 02:15 PM
DOG TEETH Removal Stalled anot... Feb 23 2025, 11:04 AM
Superhawk996 FWIW I have the same tool issue. Bought from some... Feb 23 2025, 11:30 AM
ctc911ctc Super Hawk,
Perhaps I am a bit naive, however, I ... Feb 23 2025, 12:00 PM
Superhawk996
Super Hawk,
Perhaps I am a bit naive, however, I... Feb 23 2025, 12:28 PM
ctc911ctc Agreed - my next target is an 84-86 911-SC, could ... Feb 23 2025, 04:39 PM
ctc911ctc Afternoon Update
Got the carbs off which allowed ... Feb 23 2025, 04:48 PM
ctc911ctc **********Afternoon Work Continued***********
Got... Feb 23 2025, 04:52 PM
DennisV
Cleaning the "Flap Control Boxes" used ... Feb 24 2025, 08:53 AM
ctc911ctc The flappers are in really good shape - both sprin... Feb 24 2025, 08:58 AM
Superhawk996 Is starter one of the gear reduction / Denso types... Feb 23 2025, 07:51 PM
ctc911ctc I do not think so - I do not see anything other th... Feb 23 2025, 08:31 PM
rgalla9146
I do not think so - I do not see anything other t... Feb 24 2025, 10:32 AM
ctc911ctc As always Rory has great advice - Thank you Rory -... Feb 24 2025, 10:48 AM
ctc911ctc Spent a few hours this morning traveling to get a ... Mar 1 2025, 04:59 PM
ctc911ctc Engine on Stand - Tetris with Blocks lift and pati... Mar 4 2025, 07:03 AM
ctc911ctc ********UPDATE*********
Heater Manifolds and all ... Mar 5 2025, 01:55 PM
Root_Werks Lucky enough to also have a good powder coater clo... Mar 5 2025, 03:03 PM
ctc911ctc Took the valve covers off, they were close to fing... Mar 6 2025, 07:33 PM
ctc911ctc The compression is good and ran strong, I was most... Mar 9 2025, 08:12 PM
ctc911ctc Still cleaning the engine - took off the flywheel ... Mar 10 2025, 11:15 AM
ctc911ctc Lots of progress getting rid of the grease and dir... Mar 10 2025, 07:43 PM
fixer34 Stock lower valve covers were notorious for warpin... Mar 10 2025, 08:16 PM
930cabman
Stock lower valve covers were notorious for warpi... Mar 11 2025, 04:42 PM
ctc911ctc On my small machinist table they are straight - I ... Mar 11 2025, 06:36 PM
ctc911ctc Today Did the leak down test, only could do one si... Mar 11 2025, 06:44 PM
Transmission parts arrived he... Mar 31 2025, 08:26 AM
ctc911ctc ****UPDATE*****
Pulley Seal came, time to remove... Apr 1 2025, 07:16 PM
Luke M You will want to replace the ims cover gasket.
The... Apr 2 2025, 05:13 AM
ctc911ctc Yes, I have this covered, working on flattening th... Apr 2 2025, 10:58 AM
ctc911ctc *******UPDATE*******
I pulled the plugs and perfo... Apr 11 2025, 11:06 AM
ctc911ctc
I pulled the plugs and perf... Apr 11 2025, 11:09 AM
rgalla9146 Very stout numbers for an engine that has been bas... Apr 11 2025, 01:16 PM
ctc911ctc This weekend I have been prepping to put things ba... Apr 14 2025, 11:39 AM
ctc911ctc Before and After
The Magnesium is pitted but cle... Apr 26 2025, 03:55 PM
ctc911ctc Wiring and Shroud today here are a few pictures
... Apr 26 2025, 04:01 PM
ctc911ctc I went to the hardware store and purchased some su... Apr 26 2025, 04:05 PM
porschetub
I went to the hardware store and purchased some s... Apr 26 2025, 05:57 PM
ctc911ctc I am glad you asked - I used the existing ground s... Apr 26 2025, 06:41 PM
porschetub
I am glad you asked - I used the existing ground ... Apr 27 2025, 01:39 PM
ctc911ctc
I am glad you asked - I used the existing ground... Apr 27 2025, 08:35 PM
rgalla9146 The ground strap attaches to the case just to the ... Apr 27 2025, 06:55 AM
ctc911ctc Distributor
I really like this setup, simple, no ... May 3 2025, 02:50 PM
mb911 Where is there a rebuild kit available? I remember... May 3 2025, 05:09 PM
ctc911ctc https://www.partsklassik.com/p-3794-distrib...mare... May 3 2025, 08:06 PM
ctc911ctc Here is what I am trying to fix - all of this old ... May 3 2025, 08:11 PM
Cairo94507 It may not be the same, but when we replaced the b... May 4 2025, 06:23 AM
ctc911ctc Engine Ready for the tin, looking better,
Movi... May 23 2025, 08:08 AM
ctc911ctc *******UPDATE*********
Cleaning up the engine,
... Jul 7 2025, 11:19 AM
Cairo94507 That may be undercoating applied when new. Mine h... Jul 7 2025, 12:51 PM
ctc911ctc Tooth Brush and Brake cleaner......... <_< ... Jul 7 2025, 01:06 PM
ctc911ctc What did you use for the blasting?
That may be ... Jul 7 2025, 01:38 PM
Cairo94507 It was sandblasting and scraper. Jul 7 2025, 05:15 PM
sixnotfour Dry Ice Blasting ..I saw this Six at Morris Brothe... Jul 7 2025, 05:27 PM
gereed75 Love this kind of preservation/ restoration.
Gre... Jul 7 2025, 06:31 PM
BillJ I am a huge fan of dry ice blasting. Did the whole... Jul 7 2025, 07:01 PM
930cabman
I am a huge fan of dry ice blasting. Did the whol... Jul 17 2025, 06:34 AM
ctc911ctc OK, Dry ice it is.........last time I bought dry i... Jul 7 2025, 07:40 PM
live free & drive You can get the pellets at Continental Carbonic an... Jul 9 2025, 02:32 PM
ctc911ctc Cleaning the underside of the lid, dang the old oi... Jul 13 2025, 07:40 PM
ICE ICE BABY
I spent 20+... Jul 22 2025, 07:17 PM
ctc911ctc Back from the ICE house, good kid, hard working - ... Aug 11 2025, 07:07 PM
ctc911ctc
On its way home through Boston Traffic... Aug 11 2025, 07:10 PM
Montreal914 This seems like the way to go. Looking very good... Aug 11 2025, 08:37 PM
ctc911ctc ********FUEL LINES***********
Took out the Tank -... Aug 20 2025, 12:54 PM![]() ![]() |
Lo-Fi Version | Time is now: 15th March 2026 - 08:03 AM |
