| partwerks |
Feb 9 2025, 04:38 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,619 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
What weight, and brand would be best to use in the 2005 WRX manual transmission?
| L-Jet914 |
Feb 10 2025, 01:30 AM
Member ![]() ![]() Group: Members Posts: 390 Joined: 24-October 12 From: Davis, CA Member No.: 15,080 Region Association: Northern California |
The 05 WRX transmission uses 75w90. The capacity is 3.7qts. As for brand you have Redline, Motul, Amsoil, Eneos, etc. Also from memory 3rd gear is like glass if horsepower is above a certain point. Subaru designed it that way to tell if the vehicle had been modified power wise under warranty if I remember correctly. I had a friend go through 2 transmissions on his where he lost 3rd gear and only had 1st, 2nd, 4th, 5th, R. So if you're not pushing high hp/boost, you should be okay.
Lo-Fi Version | Time is now: 14th April 2026 - 02:57 PM |
