| frank_c |
Feb 14 2025, 12:31 PM
Newbie ![]() Group: Members Posts: 20 Joined: 29-December 24 From: Austin, TX Member No.: 28,542 Region Association: None |
Hello,
I'm ordering parts to install a complete '74 style exhaust in my (new to me) '76 914 2.0. I see that the part number for the heater cable that goes from the floor lever to the valves/flappers is different for the '75+ cars. Does anyone know why that would be? Are the heater valves in a slightly different location on the '75/76 cars, resulting in different cable lengths? Or is there something different about the hand lever that requires a different cable? My car currently has no heat (and no cable), so I need to purchase a new cable regardless, I just need to know which one. Part numbers: -74: 914-424-075-01 75-: 914-424-075-03 Thanks for any info. |
| 76-914 |
Feb 14 2025, 09:48 PM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,820 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
Damn good question. I had a 76 until recently and still have 2 older 914's and I never noticed a difference. Then again I wasn't looking for that difference. (IMG:style_emoticons/default/popcorn[1].gif)
| mepstein |
Feb 15 2025, 09:21 AM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,245 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
Yes. The exhaust on a 75/76 is quite different from 70-74 and requires a slightly different length cable. Same with a 914-6 - also slightly different.
| rjames |
Feb 15 2025, 09:32 AM
I'm made of metal ![]() ![]() ![]() ![]() Group: Members Posts: 4,405 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest
My experience when I backdated was that I was able to use the cables on my late car after backdating, but they were just barely long enough.
| frank_c |
Feb 17 2025, 12:18 AM
My experience when I backdated was that I was able to use the cables on my late car after backdating, but they were just barely long enough. Thanks for the reply. Based on your response, I'm assuming that the '74 cable is longer and that is the cable I should order for a '74 exhaust in a '76 914 - did I get that right? Again, I need to order a cable either way, so I just want to avoid ordering one that is too short or won't work for some other reason. Thanks. |
| bdstone914 |
Feb 17 2025, 03:12 AM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,186 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
@frank_c
post='3192279' date='Feb 17 2025, 12:18 AM'] [quote name='rjames' post='3192053' date='Feb 15 2025, 09:32 AM'] My experience when I backdated was that I was able to use the cables on my late car after backdating, but they were just barely long enough. [/quote] Thanks for the reply. Based on your response, I'm assuming that the '74 cable is longer and that is the cable I should order for a '74 exhaust in a '76 914 - did I get that right? Again, I need to order a cable either way, so I just want to avoid ordering one that is too short or won't work for some other reason. Thanks. [/quote] .Good luck getting the correct cable. I have ordered two original Porsche cabels for different cars and both were the wrong lenght. I had to change where the 180 degree bend was and shorten one end by putting big bags in the wire. now i just use piano wire about .040" and make them longer than needed. cut to lenght after threading thru flapper valve cabel nuts. I don't use the thick barrel ends. |
Lo-Fi Version | Time is now: 21st November 2025 - 07:11 AM |
