> Squeal... ugh., Alternator bearing?
emerygt350
post Mar 12 2025, 06:27 AM
Got a squeal. It started last year, and I thought "oh, maybe just the belt". Belt is new, tightening it didn't help. Kinda goes away after the engine is hot (haven't been able to test that too much). Alternator works great. Starts to squeal as you give it a little and then stops around 2500 ish.
I still have to make sure it isn't associated with the 123distributor but if it is the alternator, what are my options? Looks like a rebuilt is around 250. Are they reliable?
bdstone914
post Mar 12 2025, 07:18 AM
bdstone914
QUOTE(emerygt350 @ Mar 12 2025, 05:27 AM) *
Current rebuilds including Bosch are often garbage. I have a great local rebuilder and can get you one for $150 plus shipping and your core. I think i have one on the shelf. If not I will drop one off today as I like to have them ready.
emerygt350
post Mar 12 2025, 07:31 AM
QUOTE(bdstone914 @ Mar 12 2025, 08:18 AM) *
That sounds great. I will pm you. I hate putting something like that on it and then have it go bad.
moldygreg
post Mar 12 2025, 09:58 AM
Stay Golden
Is the car running carbs? Just had this issue and the carb stack needed tightening down as air was getting through --- sounded like a chipmunk.
This thread was useful
http://www.914world.com/bbs2/index.php?showtopic=366666
emerygt350
post Mar 12 2025, 10:43 AM
QUOTE(moldygreg @ Mar 12 2025, 10:58 AM) *
Sadly, no, I have injection. It really is a bearing sound (and nasty). Checked the distributor as best I could but it really does sound like it's coming from the alternator.
rfinegan
post Mar 12 2025, 10:46 AM
pull the belt and start/drive..no noises= found your issue
it ok to run off battery around the block to diagnose your issues
emerygt350
post Mar 12 2025, 12:50 PM
QUOTE(rfinegan @ Mar 12 2025, 10:46 AM) *
I will do that after work today.
930cabman
post Mar 12 2025, 01:33 PM
QUOTE(emerygt350 @ Mar 12 2025, 12:50 PM) *
IIRC running the engine with the belt not connected is a no no
Double check, (IMG:style_emoticons/default/idea.gif)
My cranial cavity is getting filled
emerygt350
post Mar 12 2025, 02:45 PM
It's fine for a little bit. Happens all the time when a belt breaks.
Just tried it all the way loose, no squeal. Tighten it up so she is spinning and it squeals. Sigh. Didn't want to replace this.
brant
post Mar 12 2025, 03:01 PM
QUOTE(930cabman @ Mar 12 2025, 01:33 PM) *
on a -6... taking the belt off or losing the belt will stop the fan from cooling.
On a 4cylinder cooling will still occur
ctc911ctc
post Mar 12 2025, 03:04 PM
Just a thought - check to see if the heater fan is on - these squeal really bad when they get dirty or rusty
Low probability, however, it got me once before when the handle was down and the switch was broke.
emerygt350
post Mar 12 2025, 03:11 PM
QUOTE(ctc911ctc @ Mar 12 2025, 03:04 PM) *
Yeah, I was hoping but no, it was cold this morning so I was playing with the heater.
930cabman
post Mar 12 2025, 03:22 PM
QUOTE(emerygt350 @ Mar 12 2025, 02:45 PM) *
Can be swapped out from the bottom, a little tight but doable
emerygt350
post Mar 12 2025, 03:30 PM
QUOTE(930cabman @ Mar 12 2025, 03:22 PM) *
I have been studying the howto in the 914world stickies. Doesn't look fun, but looks doable. I just wish it had told me it was unhappy before I put the engine back together. Oh well. Thank God for all the old posts on 914world. Again, we need to make sure this resource is not lost like foureyedpride.com. This information is irreplaceable and I pity the person trying to to fix one of these without access to the wisdom left here by those before me.
emerygt350
post Mar 13 2025, 06:20 AM
Here is the video. Opinions? I still have dreams it's just the belt.
https://youtube.com/shorts/7uKmyZ8UJck?si=FShgmkwvrS0Iw9F8
930cabman
post Mar 13 2025, 06:43 AM
QUOTE(emerygt350 @ Mar 13 2025, 06:20 AM) *
If I recall it's about an hour job. Last time I did it was just getting ready heading to an event a couple hours away. Got it done and I was on my way. I do recall a bit of pressure to "force " it in there
rfinegan
post Mar 13 2025, 08:05 AM
QUOTE(930cabman @ Mar 12 2025, 02:33 PM) *
Running with out a battery is a No No for sure
emerygt350
post Mar 13 2025, 08:51 AM
Just swapped out the belt with another I have, no difference. Looks like it's replacement time.
930cabman
post Mar 13 2025, 10:23 AM
QUOTE(emerygt350 @ Mar 13 2025, 08:51 AM) *
Is there a backup in your parts inventory (IMG:style_emoticons/default/driving-girl.gif)
or a local rebuilder
emerygt350
post Mar 13 2025, 10:59 AM
bdstone914 has a rebuilder that I am using.
- Lo-Fi Version Time is now: 23rd November 2026 - 11:08 AM
