| worn |
Mar 12 2025, 06:17 PM
Winner of the Utah Twisted Joint Award ![]() ![]() ![]() ![]() Group: Members Posts: 3,544 Joined: 3-June 11 From: Madison, WI and North Bend WA Member No.: 13,152 Region Association: Upper MidWest
Hi folks. Ok, five years and the piles of parts have actually gone back onto the car. And, I er, ah tightened the head nuts to the proper torque. My problem is that it is hard to keep the motor running long enough to tune it. For example timing light.
The problem is that I want to adjust timing and fuel, but The motor isn’t running smooth enough to get there. The motor is a 2056 with the so-called Raby cam from WebCam. The MPS has been messed with, but it ran when parked. Took the motor out to split the case and address oil leaks. One thing led to another and the rust was replaced with yet to rust sheet metal, and paint etc. I am looking for a starting condition that allows enough running to improve upon. Ideally, I would like the motor to idle somehow. I have a pretty big hint. If before start, with ign on I blip the throttle a few times, the fuel injectors click, and the motor will start, run and die. From this I think that the sparks are there and the injectors are capable of letting out enough gas to fire. The fuel pressure is constant 29 psi, and the injectors have been cleaned and tested. My problem is the MPS and ECU black boxes that govern fueling. I have an AFR gauge, but it would be more useful if the motor ran long enough to get a number to look at. I am hoping for: A magic bullet post that says something like clock the seatbelt bolts and it will start, Or, basic starting adjustments for each thing that can be adjusted or tested. For example, I can static test the timing and measure MPS inductance vs vacuum. What else has to be in line? Head temp resistance value? Throttle TPS switch position or values? You folks comprise so much wisdom, so please let me get the car on the road now that spring is only months away! |
| emerygt350 |
Mar 12 2025, 06:46 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,457 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
You can have an incredibly badly tuned mps and the car will idle. I often forget to plug the vacuum line into mine when I am mucking around and end up driving it around the block like that.
I think you have a fundamental issue here. Can you keep it running by blipping the throttle or is that only for a short time? |
worn A bit more from the brain trust Mar 12 2025, 06:17 PM
worn
You can have an incredibly badly tuned mps and th... Mar 12 2025, 07:41 PM
Spoke
Can keep it going by throttle.
@worn
Can you... Mar 13 2025, 09:29 AM
worn
[quote name='worn' post='3196057' date='Mar 12 20... Mar 13 2025, 12:55 PM
emerygt350 Sounds like fuel delivery to me. Head temp sensor... Mar 13 2025, 05:20 AM
VaccaRabite What is the "So called Raby cam from WebCam... Mar 13 2025, 05:22 AM
Root_Werks
What is the "So called Raby cam from WebCam... Mar 13 2025, 02:16 PM
emerygt350 How long can you keep it running, and by running d... Mar 13 2025, 04:41 PM
worn
How long can you keep it running, and by running ... Mar 13 2025, 07:19 PM
VaccaRabite So - again. Your MPS is going to determine your f... Mar 14 2025, 04:59 AM
worn
So - again. Your MPS is going to determine your ... Mar 14 2025, 09:15 AM
emerygt350
[quote name='VaccaRabite' post='3196217' date='Ma... Mar 14 2025, 09:20 AM
emerygt350 I don't know Zach, the mps just isn't that... Mar 14 2025, 05:11 AM
worn
I don't know Zach, the mps just isn't tha... Mar 14 2025, 09:29 AM
emerygt350
I don't know Zach, the mps just isn't th... Mar 14 2025, 09:54 AM
worn
wow, that really does make me wonder about the EC... Mar 14 2025, 10:37 AM
emerygt350 Do try running it with the TPS disconnected first. Mar 14 2025, 11:06 AM
worn
Do try running it with the TPS disconnected first... Mar 14 2025, 03:33 PM![]() ![]() |
Lo-Fi Version | Time is now: 11th February 2026 - 04:24 PM |
