| worn |
Mar 12 2025, 06:17 PM
Winner of the Utah Twisted Joint Award ![]() ![]() ![]() ![]() Group: Members Posts: 3,524 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest
Hi folks. Ok, five years and the piles of parts have actually gone back onto the car. And, I er, ah tightened the head nuts to the proper torque. My problem is that it is hard to keep the motor running long enough to tune it. For example timing light.
The problem is that I want to adjust timing and fuel, but The motor isn’t running smooth enough to get there. The motor is a 2056 with the so-called Raby cam from WebCam. The MPS has been messed with, but it ran when parked. Took the motor out to split the case and address oil leaks. One thing led to another and the rust was replaced with yet to rust sheet metal, and paint etc. I am looking for a starting condition that allows enough running to improve upon. Ideally, I would like the motor to idle somehow. I have a pretty big hint. If before start, with ign on I blip the throttle a few times, the fuel injectors click, and the motor will start, run and die. From this I think that the sparks are there and the injectors are capable of letting out enough gas to fire. The fuel pressure is constant 29 psi, and the injectors have been cleaned and tested. My problem is the MPS and ECU black boxes that govern fueling. I have an AFR gauge, but it would be more useful if the motor ran long enough to get a number to look at. I am hoping for: A magic bullet post that says something like clock the seatbelt bolts and it will start, Or, basic starting adjustments for each thing that can be adjusted or tested. For example, I can static test the timing and measure MPS inductance vs vacuum. What else has to be in line? Head temp resistance value? Throttle TPS switch position or values? You folks comprise so much wisdom, so please let me get the car on the road now that spring is only months away! |
| VaccaRabite |
Mar 14 2025, 04:59 AM
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,835 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region
So - again. Your MPS is going to determine your fuel load.
It sounds like you are not using a stock cam grind. Have you adjusted your MPS for the cam you are using? Is your cam suitable for djet? What color are your spark plugs? Are they shiny and black? Are the gumming up? Zach |
| worn |
Mar 14 2025, 09:15 AM
So - again. Your MPS is going to determine your fuel load. It sounds like you are not using a stock cam grind. Have you adjusted your MPS for the cam you are using? Is your cam suitable for djet? What color are your spark plugs? Are they shiny and black? Are the gumming up? Zach Thanks for the help everyone. This is the cam card. I believe that it was Rich Towle who suggested it, but it was quite some time ago. I rebuilt the motor because of excess smoke from rings and valves and added this web cam order. ![]() Note: I ran the car and autocrossed it for a couple of years with this cam. And yes, I had to tweak the MPS and buy and use an inductance meter and A/F gauge and monitor head temps. It leaked oil though, and with the motor out I found that the body needed a lot of repair. So, this is the awakening of a motor rebuilt to fix oil leaks and set aside for 4 years. I hope that settles the cam part. Also, the motor has run recently. But it seems to be less and less willing to start. |
| emerygt350 |
Mar 14 2025, 09:20 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,444 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
So - again. Your MPS is going to determine your fuel load. It sounds like you are not using a stock cam grind. Have you adjusted your MPS for the cam you are using? Is your cam suitable for djet? What color are your spark plugs? Are they shiny and black? Are the gumming up? Zach Thanks for the help everyone. This is the cam card. I believe that it was Rich Towle who suggested it, but it was quite some time ago. I rebuilt the motor because of excess smoke from rings and valves and added this web cam order. ![]() Note: I ran the car and autocrossed it for a couple of years with this cam. And yes, I had to tweak the MPS and buy and use an inductance meter and A/F gauge and monitor head temps. It leaked oil though, and with the motor out I found that the body needed a lot of repair. So, this is the awakening of a motor rebuilt to fix oil leaks and set aside for 4 years. I hope that settles the cam part. Also, the motor has run recently. But it seems to be less and less willing to start. Interesting, so definitely run diagnostics on the MPS and verify the injectors are firing at the command of the trigger points. That should lead you to the next step. Did you put a new harness on it? |
worn A bit more from the brain trust Mar 12 2025, 06:17 PM
emerygt350 You can have an incredibly badly tuned mps and the... Mar 12 2025, 06:46 PM
worn
You can have an incredibly badly tuned mps and th... Mar 12 2025, 07:41 PM
Spoke
Can keep it going by throttle.
@worn
Can you... Mar 13 2025, 09:29 AM
worn
[quote name='worn' post='3196057' date='Mar 12 20... Mar 13 2025, 12:55 PM
emerygt350 Sounds like fuel delivery to me. Head temp sensor... Mar 13 2025, 05:20 AM
VaccaRabite What is the "So called Raby cam from WebCam... Mar 13 2025, 05:22 AM
Root_Werks
What is the "So called Raby cam from WebCam... Mar 13 2025, 02:16 PM
emerygt350 How long can you keep it running, and by running d... Mar 13 2025, 04:41 PM
worn
How long can you keep it running, and by running ... Mar 13 2025, 07:19 PM
emerygt350 I don't know Zach, the mps just isn't that... Mar 14 2025, 05:11 AM
worn
I don't know Zach, the mps just isn't tha... Mar 14 2025, 09:29 AM
emerygt350
I don't know Zach, the mps just isn't th... Mar 14 2025, 09:54 AM
worn
wow, that really does make me wonder about the EC... Mar 14 2025, 10:37 AM
emerygt350 Do try running it with the TPS disconnected first. Mar 14 2025, 11:06 AM
worn
Do try running it with the TPS disconnected first... Mar 14 2025, 03:33 PM![]() ![]() |
Lo-Fi Version | Time is now: 12th January 2026 - 01:37 PM |
