| Ron914 |
Apr 30 2025, 12:25 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 562 Joined: 19-April 22 From: Huntington Beach,Ca Member No.: 26,487 Region Association: Southern California
Thank you @Fixer34 , that is kind of you. @Ron914 , if you’re going to put both the VDO Vac gauge and AEM gauge in the pod, I could probably work this out pretty easily. I have that same AEM gauge in my personal car, so I have the data I need. What I need from you is what side, left or right, would you want the AEM? @RTz I would probably want it on the left side with the AEM on the right . Just to confirm I am interested in purchasing one of the gauge pods from you.Vacuum on the left and AEM on the right. Thanks |
| RTz |
Apr 30 2025, 12:46 PM
Newbie ![]() Group: Members Posts: 26 Joined: 18-October 24 From: Oregon City Member No.: 28,424 Region Association: None |
| Ron914 |
Apr 30 2025, 07:24 PM
Just to confirm I am interested in purchasing one of the gauge pods from you.Vacuum on the left and AEM on the right. Thanks Got it, I'll play with it this weekend and get back to you. Thanks , i am still waiting for two of my gauges to deliver and then I have to work on getting the wiring in so no hurry . |
| Ron914 |
May 4 2025, 01:44 PM
I was the one that Ron initially made this for. Finally got around to installing mine yesterday (only been a month..) and it looks like a factory option. Design point on it was to use the 52mm VDO gauges with the 2 long mounting scews attached to the back of the gauges (NOT centered), and allow access to connections/bulbs. The 'sockets' are 30mm deep so I would think most any 52mm gauge would fit. The question would be securing it in place. By the way, the gauges are easily visible just as they are; trying to make it a tilt mounting won't work due to the tight spacing of the ashtray opening. I also have the prototype build. It is a little 'rougher' so needs some finishing, and fits '72 or later with the wider ashtray dash opening (something else we discovered-'70 & '71 are narrower). If anyone is interested, I'll mail it to you and then you send Ron something for it. Pete @Fixer34 Would you still be willing to send this to me? |
Lo-Fi Version | Time is now: 24th October 2026 - 07:54 PM |
