| ChrisFoley |
Apr 17 2025, 01:22 PM
I am Tangerine Racing ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,031 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None
As far as I know, about 99% of customers have been able to complete their installation without any extra work beyond what's in the instructions.
| mb911 |
Apr 17 2025, 02:02 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,794 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest
It kind of dawned on me on me that all it really needed was for me to loosen the front mount bolts and slide back just .100” of an inch which would have been the right answer . Oh well my mistake (IMG:style_emoticons/default/biggrin.gif)
| ClayPerrine |
Apr 18 2025, 05:28 AM
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,567 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille
I recently helped @scottthephotog put one of the Tangerine shift bushings in one of his 914s. It was a problem, but not because of the bushing. The hole for the shift rod was visibly off center to the ring for the boot. So installing the bushing was challenging.
But it works fine. |
| Nate W |
Jul 26 2026, 05:40 PM
Member ![]() ![]() Group: Members Posts: 106 Joined: 23-February 21 From: Oceanside, Ca Member No.: 25,250 Region Association: Southern California
Has anyone installed one of these tangerine firewall bushings in a car with stock 914-6 shift set up? I have an early car (71 conversion) with a 914-6 tail shift transmission and shift rods with a rennshifter, which has been working well. I installed the tail shift version of the firewall bushing and now it doesn’t seem like it will shift into 1st 3rd or 5th.
Keeping it adjusted as it was before I installed the bushing I can only get the shifter into about the neutral position before the shift rod U joint hits the firewall bushing. Anyone else experience this issue? Thanks Nate |
| mepstein |
Jul 26 2026, 05:45 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,836 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
Have you called Chris at tangerine. He’s very good about supporting his products.
| jfort |
Jul 26 2026, 07:59 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,193 Joined: 5-May 03 From: Findlay, OH Member No.: 652 Region Association: Upper MidWest
Stupid question but white, black or aluminum part needed grinding? All of them. Drove the car for the first time today for any distance and I must say it did improve shifting dramatically. I am a fan For sure one of best bang for your buck improvements you can do to the car. but Add the Tangerine rear shift rod and a Jwest shifter, it gets even better. I agree. That's what I have. Shifts great. |
Lo-Fi Version | Time is now: 26th July 2026 - 08:29 PM |
