jim_hoyland |
Get that VIN ? ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,696 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California ![]() ![]() |
I have added left and right turn signal lights to my early tach. While trying to follow Spokes wiring diagram and using the BLUE / WHITE wire to each bulb; no flashing occurred. When i replace the blue/white wire with a ground it works fine.
Question is whether the flasher relay is working right. Everything else that’s supposed to flash is fine @spoke |
Spoke |
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,158 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None ![]() ![]() |
Jim,
The blue/white wire is the original configuration. If you're adding L and R indicators in the tach then just ground the common connection of the indicators. Just find a local ground on the tach for the indicators. |
jim_hoyland |
Jim, The blue/white wire is the original configuration. If you're adding L and R indicators in the tach then just ground the common connection of the indicators. Just find a local ground on the tach for the indicators. Thanks: we did what you suggested and the dash indicators work great ! (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 9th May 2025 - 05:53 PM |
