| JOEPROPER |
Apr 26 2025, 11:13 AM
The answer is "no" unless you ask... ![]() ![]() ![]() Group: Members Posts: 1,208 Joined: 21-November 15 From: White Plains New York Member No.: 19,387 Region Association: North East States
I need a late model speedometer with functioning odometer. Does anyone out there have a nice one?
joeproper |
| TheCabinetmaker |
Apr 27 2025, 04:06 PM
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,364 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
I have a few, but don't know if they work and not sure how to check when out of the car
| GaroldShaffer |
Apr 27 2025, 09:17 PM
You bought another 914? ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 7,643 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None
I have this one. Tested and everything works as it should, speedometer, odometer and trip odometer. Only issue is some dummy (me) (IMG:style_emoticons/default/slap.gif) dropped it and dented the trim ring. Pictures with the blue pen in them points to it.
If this one works for you I would take $40 and that includes shipping to you. Let me know what you think. ![]() |
| Ron914 |
Apr 28 2025, 07:54 AM
Member ![]() ![]() Group: Members Posts: 481 Joined: 19-April 22 From: Huntington Beach,Ca Member No.: 26,487 Region Association: Southern California
I have this one. Tested and everything works as it should, speedometer, odometer and trip odometer. Only issue is some dummy (me) (IMG:style_emoticons/default/slap.gif) dropped it and dented the trim ring. Pictures with the blue pen in them points to it. If this one works for you I would take $40 and that includes shipping to you. Let me know what you think. ![]() @GaroldShaffer Good morning if JOEPROPER doesn't want this I will take .I have the same problem ,my speedometer works but the odometer does not , I want to get it fixed to maintain my mileage ( I think I was messing with it and used the reset and now it doesn't work) but in the mean time I want to keep track of the miles I am adding while test driving my car. Those speedometer repair shops are so expensive I just need to put my money into getting my car running . Thanks Garold, |
| Steve |
Apr 28 2025, 08:34 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,012 Joined: 14-June 03 From: Laguna Niguel, CA Member No.: 822 Region Association: Southern California
| JOEPROPER |
Apr 28 2025, 10:07 AM
I have this one. Tested and everything works as it should, speedometer, odometer and trip odometer. Only issue is some dummy (me) (IMG:style_emoticons/default/slap.gif) dropped it and dented the trim ring. Pictures with the blue pen in them points to it. If this one works for you I would take $40 and that includes shipping to you. Let me know what you think. ![]() @GaroldShaffer I'll take it. PM me for details. Thank You! joeproper |
| Ron914 |
Apr 28 2025, 07:03 PM
| GaroldShaffer |
Apr 29 2025, 11:33 AM
I have a few, but don't know if they work and not sure how to check when out of the car You can jury rig an electric drill to turn it. You will need an old speedometer cable to attach to the drill if out of the car . Actually just the trip rest cable. One end will fit where the speedometer cable goes and use the other end in the drill. Make sure you run the drill in reverse. |
| TheCabinetmaker |
Apr 30 2025, 08:13 AM
I think i had a senior moment. I know how to test a Speedo. For some reason i was thinking about the tach. Duh!
| Ron914 |
May 2 2025, 01:31 PM
I have a few, but don't know if they work and not sure how to check when out of the car You can jury rig an electric drill to turn it. You will need an old speedometer cable to attach to the drill if out of the car . Actually just the trip rest cable. One end will fit where the speedometer cable goes and use the other end in the drill. Make sure you run the drill in reverse. When I was testing my original speedometer I think I might have run it in reverse (not knowing any better) After I replaced my cable I noticed the odometer no longer worked and the speedometer didn't quite seem to be accurate . Did I mess my original one up by doing this . @GaroldShaffer Would you happen to have a trip reset cable because I seem to have misplaced mine ? |
| euro911 |
May 3 2025, 05:08 PM
Retired & living the dream. God help me if I wake up! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,937 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California
"Use a variable speed drill and ramp up the speed slowly. Direction is the same as the direction the needle moves. Clockwise viewed from the front, ccw from the rear, so your drill should be running in reverse."
Lo-Fi Version | Time is now: 9th February 2026 - 12:09 PM |
