| bajafreaks |
Apr 26 2025, 12:35 PM
Member ![]() ![]() Group: Members Posts: 119 Joined: 7-February 14 From: Gardnerville, Nevada Member No.: 16,969 Region Association: Northern California |
I'm quite aways from having my engine completed but just wondering if there is any big advantage to pre running it before installing. It will be on carbs.
| technicalninja |
Apr 26 2025, 12:52 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,531 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region
Absolutely!
Especially a fresh engine! Bunch easier to re-adjust valves and re-torque head nuts after first full heat cycle if the puppy is out of chassis. Oil leaks are easier to spot/fix. Good/bad memories will be made... |
| bajafreaks |
Apr 26 2025, 01:41 PM
Absolutely! Especially a fresh engine! Bunch easier to re-adjust valves and re-torque head nuts after first full heat cycle if the puppy is out of chassis. Oil leaks are easier to spot/fix. Good/bad memories will be made... Kinda what i was thinking, exactly. I guess it cant be that difficult to hook up a temp fuel pump, battery, etc. The transmission would be attached anyway before installing into the car. Is there anything I'm missing? |
| mepstein |
Apr 26 2025, 03:07 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,339 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
We run almost all our engines on a test stand before installing in the car. Easier to spot leaks, noises, etc. you can put a 914 engine and trans on a pallet and run it. AIM a fan at the engine if you run it for more than a minute
| Jack Standz |
Apr 27 2025, 06:06 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 663 Joined: 15-November 19 From: Happy Place (& surrounding area) Member No.: 23,644 Region Association: None
Yes, a couple ratchet straps and a pallet works.
You should remove the alternator belt (or hook up a voltage regulator temporarily), as you'll not want to potentially destroy the alternator. |
| bajafreaks |
Apr 27 2025, 09:01 AM
We run almost all our engines on a test stand before installing in the car. Easier to spot leaks, noises, etc. you can put a 914 engine and trans on a pallet and run it. AIM a fan at the engine if you run it for more than a minute Do you do the cam break in as well ? |
| NARP74 |
Apr 27 2025, 12:40 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,446 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains |
This guy makes some stuff that helps. Maybe if you are only doing one, not worth it...
https://zalexindustries.com/ |
| 930cabman |
Apr 27 2025, 12:51 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,448 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States
In addition, I prime the oil system by cranking it over to achieve oil pressure before starting a new engine.
keep us posted with your progress |
Lo-Fi Version | Time is now: 15th January 2026 - 12:41 PM |
