tygaboy |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,566 Joined: 6-October 15 From: Petaluma, CA Member No.: 19,241 Region Association: Northern California ![]() ![]() |
I don't know that I'll ever need this again but it'd be great to have access to it, if needed. So, how about if you borrow it for your restoration and YOU store it for me? (IMG:style_emoticons/default/lol-2.gif)
Or, make me an offer that comes with a "you can borrow it back" option. Delivery possible on the west coast but let's talk details first. My chassis is a '75 so this deal comes with some super cool At The Red Barn adapter components that bolt to the factory hydraulic cylinder mounts then on to the rotisserie. If you're doing much chassis repair, or even installing a cage, a rotisserie is a total game changer. Don' tmiss this once-in-a-lifetime chance! Attached thumbnail(s) ![]() |
euro911 |
Retired & living the dream. God help me if I wake up! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,904 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California ![]() ![]() |
Sounds like a great deal, Chris (IMG:style_emoticons/default/aktion035.gif)
I have a similar, but different kind of deal ... looking for a safe & secure 'local' facility to store my 18' tandem axle flatbed trailer - where I can 'borrow' it back when I need it (IMG:style_emoticons/default/confused24.gif) ![]() It has a winch in the tool box and solar panels to keep the battery charged (IMG:style_emoticons/default/shades.gif) ![]() ![]() |
JeffBowlsby |
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,927 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None ![]() ![]() |
Chris, a couple questions?
How long is that bad boy with a chassis mounted? Not sure it will fit inside my garage, want to verify. will the mounts provided bolt up to an early car? 1974....or just the later cars via the bumper shock mounts? @tygaboy |
tygaboy |
@JeffBowlsby Jeff - those support tubes are 17' long and you can see from the pic, they're longer than the other components, even with the car on it. Plus, if you need something like this but it's maybe a bit too long, those silver brackets that run from the unit to the chassis could easily be shortened and still allow for work on the rear of the car.
And those brackets I mentioned are just to better support the chassis via the factory BUB mounting locations but aren't needed. The rotisserie works with an early chassis, too. You just don't use my brackets. And given you location, I'd be happy to deliver, if needed. Hope this helps. |
markhoward |
Member ![]() ![]() Group: Members Posts: 393 Joined: 5-March 17 From: Lafayette, CA Member No.: 20,897 Region Association: Northern California ![]() ![]() |
I imagine the support tubes could be cut and sleeved with a smaller/larger diameter pipe to make each support tube more than one piece. That would make the package smaller when stored.
worn |
Winner of the Utah Twisted Joint Award ![]() ![]() ![]() ![]() Group: Members Posts: 3,486 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest ![]() ![]() |
@JeffBowlsby Jeff - those support tubes are 17' long and you can see from the pic, they're longer than the other components, even with the car on it. Plus, if you need something like this but it's maybe a bit too long, those silver brackets that run from the unit to the chassis could easily be shortened and still allow for work on the rear of the car. And those brackets I mentioned are just to better support the chassis via the factory BUB mounting locations but aren't needed. The rotisserie works with an early chassis, too. You just don't use my brackets. And given you location, I'd be happy to deliver, if needed. Hope this helps. I have the solution. You can both store your stuff with no worries in rural Wisconsin. They will nestle near my WWII vintage lift. Bring them over! |
JeffBowlsby |
@tygaboy
I will need to pass on this Chris. Beautiful rotisserie but its quite large and I'll try to get done what I need to without it. |
euro911 |
I imagine the support tubes could be cut and sleeved with a smaller/larger diameter pipe to make each support tube more than one piece. That would make the package smaller when stored. ... or transported (IMG:style_emoticons/default/shades.gif) |
nivekdodge |
Member ![]() ![]() Group: Members Posts: 306 Joined: 28-August 21 From: Pittsburgh Pa Member No.: 25,860 Region Association: MidAtlantic Region ![]() ![]() |
I don't know that I'll ever need this again but it'd be great to have access to it, if needed. So, how about if you borrow it for your restoration and YOU store it for me? (IMG:style_emoticons/default/lol-2.gif) Or, make me an offer that comes with a "you can borrow it back" option. Delivery possible on the west coast but let's talk details first. My chassis is a '75 so this deal comes with some super cool At The Red Barn adapter components that bolt to the factory hydraulic cylinder mounts then on to the rotisserie. If you're doing much chassis repair, or even installing a cage, a rotisserie is a total game changer. Don' tmiss this once-in-a-lifetime chance! Chris and all, It's so much of a game changer, I keep dreaming of a suction system to remove the oil and fuel to use one all the time! Kevin |
Graydingo |
Member ![]() ![]() Group: Members Posts: 67 Joined: 12-August 22 From: Las Vegas Member No.: 26,768 Region Association: Southwest Region ![]() |
Want to take a trip to Fabulous Las Vegas? I could definitely use the rotisserie for my 75 914. I also have two custom made yokes for a 911. I would donate the 911 yokes to the deal in return for the use of it. I'll also pay your gas expenses here. Nice thing about Vegas is I'm 4 hours to LA, and 4 hours to Phoenix for the next 914/911 guy. Also close to Southern Utah only a few hours away there.
Lo-Fi Version | Time is now: 1st June 2025 - 06:34 AM |
