> Center Appearance Group Console Repro, AA vs 914Rubber?
StarBear
post May 18 2025, 01:05 PM
Thinking of finally replacing my original Appearance Group console. Mostly ok but for past 30+ years the right side top has had ugly black electrical tape to cover the split vinyl. (IMG:style_emoticons/default/mad.gif) Haven’t been able to find a concours grade right side piece. (IMG:style_emoticons/default/hissyfit.gif)
Am tending toward the AA unit but interested in folks’ thoughts and experiences.
PM if that’s more comfortable. (IMG:style_emoticons/default/beerchug.gif)
914werke
post May 18 2025, 01:17 PM
There is an alternative (IMG:style_emoticons/default/idea.gif)
edrotol
edrotol
What are you looking for.
Have a pristine concourse piece but I need details. My name is Ed.
Edrotol@verizon.net
dr914@autoatlanta.com
post May 18 2025, 01:52 PM
really impossible to find as the covers were heat seamed. If you have an original console, our new trim girl, Nora, recovers them with real stitching that looks like the heat seamed stuff, and for a concours car that is what I would do
StarBear
post May 18 2025, 02:29 PM
QUOTE(914werke @ May 18 2025, 03:17 PM) *
What might you suggest? Open to new ideas.
StarBear
post May 18 2025, 02:30 PM
QUOTE(edrotol @ May 18 2025, 03:17 PM) *
Edrotol@verizon.net
I’ll check in with you. Thanks!
StarBear
post May 18 2025, 02:32 PM
QUOTE(dr914@autoatlanta.com @ May 18 2025, 03:52 PM) *
George; that’s an idea. (IMG:style_emoticons/default/beer3.gif) Would I send in the whole unit (diassembled if possible)?
How would the cost compare with one of your reproduction units?
StarBear
post May 19 2025, 07:33 AM
Pics always help. Here they are.
Original, but judges keep nicking me several tenths of a point for this patch job and the heat-sealed seams.
StarBear
post May 19 2025, 09:28 AM
QUOTE(914werke @ May 18 2025, 02:17 PM) *
Yes; “Do nothing else” has been my choice for the past 30 years or so. (IMG:style_emoticons/default/dry.gif)
post May 19 2025, 09:47 AM
Although our repro center console is identical in dimension to the original to make up for the thickening profile on the top, we use thicker wood. We have had the original bracketing reproduced, the plastic insert and use a nice looking vinyl shift boot. The stitching resembles the original heat seamed factory profile, and we even have had the original larger gauges reproduced. HOWEVER, in no way would it pass the concours muster for originality unless a judge did not know EXACTLY how the original should look. THEREFORE I would have yours recovered or look for an original needle in a haystack. Funny, for awhile, Porsche reproduced them and they looked TOTALLY home made with hand made stitching instead of the heat seam. OURS look FAR superior to the short lived factory reproduction
Montreal914
post May 19 2025, 01:12 PM
I would try to find an original side. They are still around. Every picture of replicas I have seen have the top seams pointy instead of flat like the original.
BTW, liking how you are hiding the Rennshift (?) tower. Please provide more pictures. I was potentially thinking of doing something like that and remove the lip on the top ring where the CV join boot latches on.
Good luck with your search!
StarBear
post May 19 2025, 01:39 PM
QUOTE(Montreal914 @ May 19 2025, 02:12 PM) *
@Montreal914
Sure! Got some "nice" leatherette on eBay, made a template for a tower base, shaved the ring thingie under the boot, shaved the bottom panel opening to fit the larger tower diameter, and stitched the original boot to the riser (that was the hardest part). JWest shifter, but same for Rennshift I'd imagine.
Here are pics:
Montreal914
post May 19 2025, 02:00 PM
Nice!!! (IMG:style_emoticons/default/smilie_pokal.gif)
Thank you for sharing. Actually makes that tower stealth and skinnier.
BTW, Rennshift is the product name for JWest Engineering’s shifter. (IMG:style_emoticons/default/biggrin.gif)
SO.O.C914er
post May 19 2025, 09:32 PM
You can do a lot of fun stuff moving it from standard trim. Here’s mine and maybe Eddie sb914 the Seal Beach legend can share his. Been a few years since I saw it last but I believe it’s carbon fiber material matches his dash board! Pretty trick looking.
PanelBilly
post May 19 2025, 10:32 PM
I had my original. Covered with leather when I had the seats done. I’ll take some pictures and post them tomorrow. It’s not OEM but makes me happy
StarBear
post May 20 2025, 05:41 AM
So nice to what others are doing. Very inventive crew.
sb914
post May 20 2025, 07:22 AM
Surf Guru
QUOTE(SO.O.C914er @ May 19 2025, 08:32 PM) *
Attached Image here’s mine .Attached Image
StarBear
post May 20 2025, 09:05 AM
QUOTE(sb914 @ May 20 2025, 09:22 AM) *
Fabulous!! Very modern looking. And a cup holder, too! I think my old hanging cup holder is what did in my right side top edge.
PanelBilly
post May 20 2025, 10:24 AM
Not exactly OEM but similar. Switch is for Bluetooth receiver
914werke
post May 20 2025, 11:16 AM
As has been suggested AA & the Rubber guys aren't the only that provide the service Ive been rebuilding & restoring since Barberdave so many yrs ago.
The repops use a thicker plywood base than the OE so always look chunkier so I try to restore the original parts. The shifter floor is the trickiest to get looking right.
2 User(s) are reading this topic (1 Guests and 0 Anonymous Users)
1 Members: Craigers17
- Lo-Fi Version Time is now: 21st May 2025 - 07:25 AM
