racerx9146 |
good design never goes out of date.. ![]() ![]() Group: Members Posts: 174 Joined: 1-January 04 From: Sacramento, CA Member No.: 1,483 Region Association: Northern California ![]() |
Morning
This weeks garage clean-out special 108 mm 4 bolt/2 pin 911 stub axles for use with larger axles. $100 plus shipping from 95650 via USPS ground advantage. Paypal preferred. Please send a specific address so I can give you an accurate shipping quote before you pay. I am including the outer hubs as well as you get the wheel studs. I don't think you can use them w/o machining or spacers as the bearing width is different or something. I forget. regards Daron ![]() ![]() ![]() |
Steve |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,881 Joined: 14-June 03 From: Laguna Niguel, CA Member No.: 822 Region Association: Southern California ![]() ![]() |
These look like the early 72-73 stuff? I have these on my car. Spacers are only needed with the later hub centric setup. PMS sells the spacers.
69146 |
I'm new here ... Group: Members Posts: 0 Joined: 18-August 23 From: Oldsmar Member No.: 27,532 Region Association: None ![]() |
Morning This weeks garage clean-out special 108 mm 4 bolt/2 pin 911 stub axles for use with larger axles. $100 plus shipping from 95650 via USPS ground advantage. Paypal preferred. Please send a specific address so I can give you an accurate shipping quote before you pay. I am including the outer hubs as well as you get the wheel studs. I don't think you can use them w/o machining or spacers as the bearing width is different or something. I forget. regards Daron ![]() ![]() ![]() Do you have any pics off the stub axle shafts. The hubs look like the aer on backwards? |
racerx9146 |
yes they are on backward for storage space!
Montreal914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,841 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California ![]() ![]() |
pm sent.
69146 |
Are they sold?
69146 |
If not I’ll take them
Montreal914 |
Looks like there is a line (IMG:style_emoticons/default/smile.gif)
Lo-Fi Version | Time is now: 15th June 2025 - 12:30 PM |
