> Rear Red Turnsignals Double as Brakes, Increase Brake Lights with Rear Turnsignals
Spoke
post Jun 17 2025, 01:27 PM
Jerry
Engelbert designed a solution for the 911 to allow the rear turnsignal to double as brake lights for a larger brake footprint. I believe he is planning to market it for the 911 guys. Because of the layout of the 911 rear light housing, to install the module in the housing, the housing has to be removed and opened up.
I thought this would work well for the 914 and should be easy to install as access to the rear housing and wires is in the trunk. Engelbert was ok with me basically copying his solution.
Here's a link to his 911 solution:
rothaus (Engelbert) 911 RTS to Brakes
The RTS-Brake module would reside below each rear light housing. One for each side. Here's the module being tested on the bench.
https://www.youtube.com/watch?v=i5h_pG7AQ9A
The module has 6 wires. Brake-in, Brake-out, RTS-in, RTS-out, and 2 grounds. The wires have QC connectors and go between the OEM wiring and the light housings.
The IN wires have male connectors and the OUT wires have female connectors.
On each side, pull the brake, RTS, and GND wires from the housing. The wires connect to the IN wires and the OUT wires goes to the housing.
On my '71, the RTS QC connectors don't have insulation so a short piece of heat shrink provides the insulation.
Once the RTS connectors are insulated, pull one wire at a time and install.
Here are the modules in action on my 914. My 914 is set up to always have the running lights on with the ignition.
https://www.youtube.com/watch?v=RHFrilGntQM
I built an extra set if someone would like to try them out. If folks are interested, I'll be selling these for $45/pair.
FlacaProductions
post Jun 17 2025, 03:52 PM
Hey Jerry - of course I'd love to try em out but I'm a few weeks away from being back with the 914. So....if you provide a link, I'm all in on these. You can't have too much light on these little cars!
slowrodent
post Jun 17 2025, 04:00 PM
Very very practical and very good looking.... Looks as if I'd better start saving a few $$$ up soon. (IMG:style_emoticons/default/idea.gif)
post Jun 17 2025, 04:38 PM
914-6 GT in waiting
Your products (and support) are always top notch.
2 pairs please.
Cairo94507
post Jun 17 2025, 04:54 PM
Michael
Boy... I run the Euro rear lenses on my 6 but really like the idea of adding more light when stepping on the brake pedal. I will have to think about this as I love all things Spoke Works which make our cars, in my humble opinion, much safer on the road. (IMG:style_emoticons/default/beerchug.gif)
Spoke
post Jun 17 2025, 05:13 PM
Jerry
QUOTE(mepstein @ Jun 17 2025, 06:38 PM) *
2 pairs please.
@mepstein
Mark,
Sounds good. I'll have these in the mail tomorrow. I don't have any 1/4 heat shrink tubing on hand for the RTS connector if it is bare like my '71. I used a 1 inch piece for each side. Electrical tape would do in a pinch. Please PM your address.
Olympic 914
post Jun 17 2025, 05:16 PM
I will also be in for a set.
When can we place an order?
Spoke
post Jun 17 2025, 07:12 PM
Jerry
QUOTE(Olympic 914 @ Jun 17 2025, 07:16 PM) *
Hi Tom,
I've added the modules to my website.
Are you going to the Pittsburgh Historic Grand Prix car show? I'll be there with my 914.
JmuRiz
post Jun 17 2025, 07:16 PM
Great idea, I’ll have to add to my parts stash
Spoke
post Jun 18 2025, 07:40 AM
Jerry
Here's a connection diagram for these RTS-Brake modules. Connecting these modules is straightforward. Pull one wire at a time and plug the OEM wire into the corresponding module wire color and wire color to the housing.
All the connection information and OEM wire colors were used from Jeff Bowlsby's diagram:
ValcoOscar
post Jun 18 2025, 07:53 AM
Garage Life
Just terrific...
I'm in for TWO(2) sets. (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/beer.gif) (IMG:style_emoticons/default/beer3.gif)
DONE....PAID
Thx
O
jim_hoyland
post Jun 18 2025, 10:02 AM
Get that VIN ?
Nice upgrade Jerry, I’ll order a set (IMG:style_emoticons/default/smile.gif)
PM sent re address correction, send to PO Box 901 ….
@Spoke
gonzo54
post Jun 18 2025, 10:54 AM
Orange Crush
@Spoke , I have your LED Brake Boards on my car but have not upgraded to the LED turnsignal boards. Will this mod work with my incandescent turn signal bulbs or will I need to upgrade to LED?
Thanks-Rick
Spoke
post Jun 18 2025, 12:35 PM
Jerry
QUOTE(gonzo54 @ Jun 18 2025, 12:54 PM) *
Thanks-Rick
Yes it should work. These are 2Amp relays and the 1056 21W bulbs should only draw about 1.8Amp. It is close but should work.
JeffBowlsby
post Jun 18 2025, 02:52 PM
Do I see piggyback terminals on the left side housing connections? If so, are they needed?
Spoke
post Jun 18 2025, 05:48 PM
Jerry
QUOTE(JeffBowlsby @ Jun 18 2025, 04:52 PM) *
Good eye. I didn't want to comment on that just to keep things simple. The piggyback connector is for my 3rd brake light on the roll hoop. I steal brake power from this pin.
Here's a description of my 3rd brake light install:
3rd Brake Light Install
Stratfink
post Jun 19 2025, 11:10 PM
Ordered this morning along with the brake, turn signal and reverse light boards!
Spoke
post Aug 31 2025, 12:45 PM
Jerry
With a simple jumper, the brake can also function as turnsignal/brake. This works only for LED brake and turnsignal because of the high current of incandescent bulbs.
Here's a video of the RTS-Brake with the brake also doubling as the RTS.
https://www.youtube.com/watch?v=fu5en-uRFaE
Montreal914
post Aug 31 2025, 01:47 PM
Very nice product! (IMG:style_emoticons/default/driving.gif)
Just to be clear, on the combined turn signal/brake setup (video in post 18), what happens when you hit the brakes with the turn signal on, does the turn signal splits back from the brake so you still have a brake light on next to the flashing light?
In your first video, you had EU lenses with red LEDs in the back. Always difficult to see the shade of the light on camera. Was there a big difference betwheen the red of the brake lens portion and the red through the amber portion? If not, could the turn signal board be populated with both red and amber LEDs to serve as two functions? (IMG:style_emoticons/default/idea.gif) I definitely love the idea of having more brake lights, but I want to keep my EU lenses and amber turn signal.
Looking at buying your products but since I am not about to drive my car (IMG:style_emoticons/default/rolleyes.gif) , I am sort of waiting for the ever going product improvement and selection. (IMG:style_emoticons/default/smilie_pokal.gif)
Cairo94507
post Aug 31 2025, 02:27 PM
Michael
Great question by Montreal914. I would love to do this modification, but love me EU rear turn signals. (IMG:style_emoticons/default/beerchug.gif)
- Lo-Fi Version Time is now: 13th September 2025 - 04:32 AM
