 Forum Rules Classified Rules!
> Race Car For Sale, 1974 914-6
timgreen
post Jun 17 2025, 04:43 PM
I am selling my 1974 914-6 race car known as POLIZEI - $30,000 OBO
Original SCCA car from Pennsylvania (roll bar number 31-028)
ENGINE:
2.7L from ‘76 911, upgraded to 275HP
Race prepared Weber duel 3-barrel carburetors, dual plug heads
Electromotive crank-fire ignition
Custom J&E 11:1 compression pistons
911 turbo oil pump
Oversized valves, heads prepared by Werner Machine
JWE (Jerry Woods) performance cams similar to GE-40)
911 and large Fram oil filter
Engine built and dyno’d by CS Motorsports
Rich Johnson engine mount
Cable accelerator
Centerforce racing clutch with hydraulic actuator
Streb oil cooler
Peterson 4 gallon oil tank
AN-16 & AN-20 oil lines
TRANSMISSION:
901 side shifter transmission (1975) with custom gears (A,F,M,S,X)
Quaife limited slip 7/31 ring & pinion
Trans oil cooler with electric pump
Custom 915 style shifter with reverse lockout
Hydraulic clutch
930 turbo CV joints
SwayAway custom axles
SUSPENSION:
Rich Johnson drop spindles with coil over modification
Custom trailing arm modification for better control
Koni double adjustable shocks
Custom front sway bar
CUSTOM DASH: (Autometer gauges)
10,000RPM Tachometer with shift light
Oil pressure
Oil temperature
Trans oil temperature
Fuel pressure
Battery voltage
30psi oil warning light
BRAKES:
Tilton brake and clutch pedals w/ remote Revisor
Wilwood 6-piston front and 4-piston rear racing calipers
BODY:
Safe door cage
Updated front bars
Baker nose & fenders
Fiberglass hood
Lightened doors
Lightened trunk
Fuel Safe fuel tank
Custom seat
- Lo-Fi Version Time is now: 3rd July 2025 - 02:47 PM
