| gfg3 |
Jun 22 2025, 07:49 AM
Never Too Old ![]() ![]() Group: Members Posts: 127 Joined: 5-January 15 From: Southern Virginia Member No.: 18,295 Region Association: None |
My '75 1.8 has developed a vibration when in 5th gear. All other forward gears and reverse work just fine. Am I looking at tearing the trans apart or maybe a CV joint?
Thanks. George |
| jim_hoyland |
Jun 22 2025, 07:58 AM
Get that VIN ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,062 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California
Is the vibration constant at various RPMs ? Does it dissipate at say 4K ?
| mlindner |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,765 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest
George, under load in 5th, decelerating, coasting at speed in nuetral?
| gfg3 |
Jun 22 2025, 10:21 AM
Seems constant under constant load plus accel & decel. Coasting it goes away. Also goes away when I downshift into 4th.
| gfg3 |
Jun 24 2025, 07:35 AM
Any ideas, folks? I'm really baffled about this and don't want to tear out the trans unless I have to.
George |
| Shivers |
Jun 24 2025, 07:49 AM
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,367 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
Any ideas, folks? I'm really baffled about this and don't want to tear out the trans unless I have to. George Sounds like a good time to paint your drive axles and inspect and lube your CV's. If you find a bad one problem solved, if not you know where you need to look next and the axles are already out of the way. I hope it is a bad CV. |
| Cairo94507 |
Jun 24 2025, 11:11 AM
Michael ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,621 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California
CV's are my first thought too. (IMG:style_emoticons/default/beerchug.gif)
| dr914@autoatlanta.com |
Jun 24 2025, 11:21 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,236 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
| gfg3 |
Jun 25 2025, 09:50 AM
Thanks everyone. Once the temps get below the high-90s here in Virginia, I'll slide under the car and take a look.
George |
Lo-Fi Version | Time is now: 1st May 2026 - 03:17 AM |
