oakdalecurtis |
Oakdalecurtis ![]() ![]() ![]() Group: Members Posts: 1,373 Joined: 5-June 15 From: Oakdale, Ca Member No.: 18,802 Region Association: Central California ![]() ![]() |
76 2.0 FI, 130,000 miles, stock except for Crane Fireball electronic ignition.
Has been running flawlessly until the last week, now the idle has dropped to 4-500 rpm and stalling at lights. -The idle screw has always affected the idle rpm, now it makes no difference how far out the screw is set. -Removed air cleaner (has new air filter), air going directly into throttle body makes no difference to low idle. -Valves were done a few thousand miles ago I am taking it to my mechanic to have new spark plugs installed and remove the injectors to send in for a rebuild. I'm hoping this might affect the idle. Any thoughts on what might account for the lack of idle all of a sudden to point my mechanic towards? |
emerygt350 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,043 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States ![]() |
Check your timing at idle when it is 'low'. Check to see if your mps is holding vacuum.
oakdalecurtis |
windforfun |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,057 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None ![]() ![]() |
Google it. You’ll enjoy all the reading.
rjames |
I'm made of metal ![]() ![]() ![]() ![]() Group: Members Posts: 4,325 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest ![]() ![]() |
Check your timing at idle when it is 'low'. Check to see if your mps is holding vacuum. Hi Emery, I know what the mps is, but at the risk of asking a silly question, how do I check the vacuum? Disconnect the hose going to it and use a hand vacuum pump like a MityVac to pull ~15inHg on it and see if it holds there for 5 minutes. If it won’t hold vacuum then the diaphragm inside it is probably cracked and needs replacing. |
emerygt350 |
Leaving you with an over rich condition at idle.
Lo-Fi Version | Time is now: 17th July 2025 - 10:17 PM |
