> Subaru EJ20DETT Transplant
fiid
post Jul 31 2003, 09:43 AM
Post #21
Turbo Megasquirted Subaru Member
Hey all,
I have obtained a Subaru EJ20DETT motor that I intend to put in my 914.
For those not familiar with this motor - here is some info:
Water cooled flat 4 - twin turbos- staged.
276hp, 252.98 lbft torque
The engine also has coil-over-plugs. (i.e. there is a small coil mounted over each spark plug).
My plans fror the project are:
Use Ron Simpson Radiator, and some sheet metal that allows me to retain use of the front trunk. Spare tire in rear trunk.
Rebuild 901 box with billet intermediate plate, side cover, and limited slip.
Mount engine to tranny using KEP adapter.
Fabricate engine mount and exhaust (I'm thinkin 2 glasspacks should do it).
Here are the questions:
How do I get the thing to fire (anyone know of projects or products that can drive 4 coils and no distributer)???
Any better solutions to the transmition question? Should I run a 915? What do you guys think?
I have uprated the suspension to 23mm front sway bars with weltbushings, konis all round and 180lb rear springs. I intend to put bmw front calipers on it and it has a 19mm front master cyl.
Opinions? Ideas? I think this thing is going to rock when it's done!
Fiid. (IMG:style_emoticons/default/aktion035.gif)
fiid   Subaru EJ20DETT Transplant   Jul 31 2003, 09:43 AM
aufaber   It's been done a few times now, there are also...   Jul 31 2003, 10:12 AM
Mueller   There are a few Subaru powered 914's running a...   Jul 31 2003, 10:29 AM
Brad Roberts   Mike.. You have met Fiid 3-4 times at Roadglue ev...   Jul 31 2003, 11:13 AM
Brad Roberts   Oh.. if you have the money... shoot for the 915 bo...   Jul 31 2003, 11:15 AM
aufaber   And if you've got the money for a 915, then yo...   Jul 31 2003, 12:17 PM
fiid   The thing I like about the Rod Simpson radiator is...   Jul 31 2003, 12:18 PM
fiid   <...   Jul 31 2003, 12:21 PM
airsix   For the 911 suspension you can just use the 911 st...   Jul 31 2003, 12:39 PM
Hawktel   What if you added side scoops, hung 2 radiators in...   Jul 31 2003, 12:43 PM
redshift   I haven't driven a 915 converted 914 in a whil...   Jul 31 2003, 01:45 PM
fiid   <...   Jul 31 2003, 02:17 PM
fiid     Jul 31 2003, 02:20 PM
redshift   The rears can be drilled for about $100.00, a...   Jul 31 2003, 02:25 PM
fiid   Another question..... I have a lightened flywheel...   Jul 31 2003, 02:27 PM
airsix   Regarding 911 struts and 5-lug rear hubs: When I s...   Jul 31 2003, 03:06 PM
soloracer   Sounds like a fun project. If you plan on keeping...   Jul 31 2003, 06:09 PM
fiid     Aug 25 2003, 12:18 AM
jonwatts     Aug 25 2003, 12:39 AM
fiid   ...   Aug 25 2003, 09:37 AM
Malmz   ...   Aug 25 2003, 09:52 AM
fiid   Jon Watts - where are you???? :-) Time to talk pr...   Sep 22 2003, 03:24 PM
fiid   Oh yeah- does anyone know where I can get a wiring...   Sep 22 2003, 03:25 PM
cha914   I don't know if you have seen these forums yet...   Sep 22 2003, 08:21 PM
jonwatts     Sep 22 2003, 09:05 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 08:16 PM
