Literati914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,053 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region ![]() |
My battery was bought last month.. Alternator light comes on with the key on, but goes out at start up. Battery keeps running low and eventually won't start the car. Does this point to anything usual - VR maybe?
GregAmy |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,531 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States ![]() ![]() |
Does this point to anything usual - VR maybe? What is the voltage directly at the battery when the car is running? post #15 in this thread is gold: http://www.914world.com/bbs2/index.php?showtopic=326479 https://www.pelicanparts.com/techarticles/9...roubleshoot.htm https://www.pelicanparts.com/techarticles/9...roubleshoot.htm |
fixer34 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,316 Joined: 16-September 14 From: Chicago area Member No.: 17,908 Region Association: Upper MidWest ![]() ![]() |
Could be several things but VR is a likely suspect. Had this same thing for quite a while, went thru several old style VRs (used). Voltage to battery was around 12, so enough to turn off the light but not adequately charge.
Finally installed Bosch electronic VR, that did the trick. |
TheCabinetmaker |
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,350 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 ![]() |
Check the belt tension
Lo-Fi Version | Time is now: 10th August 2025 - 11:05 AM |
