Ishley |
Member ![]() ![]() Group: Members Posts: 253 Joined: 4-October 21 From: Clarendon Hills Il Member No.: 25,957 Region Association: Upper MidWest ![]() ![]() |
So after spending last weekend replacing my throttle cable on my '72 Djet car... a few days later (of course) my clutch cable started to go. So today I'm back at the pedal cluster (uggh) and replacing the clutch cable. I have the cable all run and into the pedal cluster so no issues there.
The kit I ordered from 914 rubber came with a tab washer... Mine did not have this installed. So I'm scratching my head now where this goes. I believe it goes at the connection point where the cable meets up with the bearing bracket. Does it go inside (where the wheel is) or outside towards the engine? Why is it shaped this way? Is there supposed to be an E-clip holding this all together? I'd like to make sure everything is right. Attached image(s) ![]() |
NARP74 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,402 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains ![]() |
The point of the tab bends into the hole on the plate where the clutch cable deflection roller is by the trans. Where the cable slots into the holder in the rear.
Ishley |
Thanks! I couldn’t find any pics to show me the way.
Ishley |
Final results for the person searching for a solution in the future.
930cabman |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,217 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States ![]() ![]() |
NARP74 |
That is how it got the nickname, the beer can pull tab.
Lo-Fi Version | Time is now: 16th August 2025 - 04:59 AM |
