> Oil Appears Overfilled, Should I Remove to the MAX Line
PlantMan
post Aug 17 2025, 05:35 PM
I just found time to check the oil in the car (914/6 conversion 2.4 spec).
After bringing it to temp and ensuring the car was on a level area, I pulled the dip stick several times, cleaning after each pull, the oil appears to be significantly higher than necessary, at least 1" past MAX.
The car was running at the time of the check.
1. Should I check with the car not running as well?
2. Time to remove and refill to the proper level?
Thanks all.....
Trying to figure out the specifics of the '6' with the little time I have currently.
10 User(s) are reading this topic (6 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 18th August 2025 - 03:50 PM
