s13u74cr4 |
Newbie ![]() Group: Members Posts: 37 Joined: 2-September 23 From: PNW Member No.: 27,558 Region Association: Pacific Northwest ![]() |
Anyone have a dust cover for the heater control box lying around for a 73? Think I am just going to cap that off in the summer, cap the inlet into the firewall, and route the excess over to the side per the vapor lock Porsche tweak doc.
DC_neun_vierzehn |
Senior Member ![]() ![]() ![]() Group: Members Posts: 567 Joined: 16-November 20 From: Coastal Delaware Member No.: 24,893 Region Association: MidAtlantic Region ![]() ![]() |
Do you have a pic or can you show in a parts diagram what you're referencing?
bdstone914 |
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,089 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
@DC_neun_vierzehn
date='Aug 25 2025, 03:04 PM' post='3221117'] Do you have a pic or can you show in a parts diagram what you're referencing? [/quote] I think he means the Heater flapper valve hat But I don't know why you need one if doing the vapor lock update which removes it. @s13u74cr4 Like this? Attached thumbnail(s) ![]() |
s13u74cr4 |
[quote name='bdstone914' date='Aug 26 2025, 01:53 AM' post='3221214']
@DC_neun_vierzehn date='Aug 25 2025, 03:04 PM' post='3221117'] Do you have a pic or can you show in a parts diagram what you're referencing? [/quote] I think he means the Heater flapper valve hat But I don't know why you need one if doing the vapor lock update which removes it. @s13u74cr4 Like this? [/quote]i Ohh, I mean the other side that would go into the hose-->opening in the firewall for the heat. I thought the dust cap would fit either side but maybe not? Regardless, something to cap off the other side of the box. |
Montreal914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,899 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California ![]() ![]() |
The heater valve Bruce is showing is connected to the tube that lives in the long via a flexible duct. There is no cap there.
What some people have been using to cap off the inlet tube (longitudinal) is a rattle can paint cap. Hope this helps. (IMG:style_emoticons/default/confused24.gif) |
bdstone914 |
The heater valve Bruce is showing is connected to the tube that lives in the long via a flexible duct. There is no cap there. What some people have been using to cap off the inlet tube (longitudinal) is a rattle can paint cap. Hope this helps. (IMG:style_emoticons/default/confused24.gif) You can buy an expandable rubber plug off Amazon. It has a bolt in the center that expands the rubber. I did not find paint cars fit well and you have to fashion some kind of clamp to keep them on.0 |
DC_neun_vierzehn |
The heater valve Bruce is showing is connected to the tube that lives in the long via a flexible duct. There is no cap there. What some people have been using to cap off the inlet tube (longitudinal) is a rattle can paint cap. Hope this helps. (IMG:style_emoticons/default/confused24.gif) You can buy an expandable rubber plug off Amazon. It has a bolt in the center that expands the rubber. I did not find paint cars fit well and you have to fashion some kind of clamp to keep them on.0 Do you have a link for that @bdstone914 ? |
s13u74cr4 |
I did put a spray paint cap on the side going into the auto. Thought if I did the same on the other end it would melt. I like your idea better @bdstone914 , link?
bdstone914 |
I did put a spray paint cap on the side going into the auto. Thought if I did the same on the other end it would melt. I like your idea better @bdstone914 , link? .search for rubber expansion plug. Many sources |
Lo-Fi Version | Time is now: 29th August 2025 - 05:23 AM |
