| wonkipop |
Sep 10 2025, 07:34 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,783 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille
it has been mentioned in a number of topics on this site that these may be images of the same car.
to left present condition of car - to right a possible image of it in an earlier original state. a speculation perhaps triggered by the present condition of the tangerine orange car with self evidently incorrect rims appearing to belong to the 74 model year instead of original 70 model year rims. leading to some suggestions that the car has been "freshened up" either significantly or in a minor degree along the way and that the image to right is therefor its original state. ----------- recently i stumbled across this much higher resolution image of the car to the right. this reveals details that make it clear the two cars are not the same car. see notes on image. its very clear that the more red-(ish) car is either a prototype car, one of the 8 known to have been built in 1968 or a pre-production car prior to the full production run. the big giveaway is the jacking point in the rocker panel. it is situated low down near the underside not near the top as production cars had. images of surviving prototype cars share this position of the jack point lower down. refer the piech 914/8 which made use of a 1968 prototype body as its basis. some other details become clear as well. the lack of interior trim panels on the targa bar. both side and top trims are missing. probably not yet hand made as a part and not fitted to this very early prototype car. unlike the very early base model 4s it does not have horn grilles painted body color to match the body colored bumpers. in addition the plastic headlight surrounds are body color when the production cars had white surrounds. the sail panel trims are chrome even though the sail panel is body colored (no vinyl). the very same car gets used for very early publicity shots for brochures at the time of the cars launch. its not this car. they are not both necessarily the same color "red" cars. the prototype car could be a deeper red. there is no mistaking the #1 production line car as tangerine. photo colors are not necessarily reliable. the #1 car exhibits all the features consistent with an early year production cbase model 4. body colored bumpers with matching painted horn grilles. body colored sail panel trims. who knows what color headlight surrounds are as i can find no image anywhere with the headlights up. but i will bet they are white. (IMG:style_emoticons/default/smile.gif) this image taken from projected images that were part of the 50 year exhibition of the 914 at the porsche museum could be the tangerine #1 car in its original state before the fitment of update 74 VW sport rims. although it appears to have a radio aerial and i can't detect one on the recently taken images of the tangerine #1 car. whatever, it once would have had the VW embossed hubcaps. ![]() as an aside the sport rims fitted to VW #1 are not in fact correct. they are the deeper offset 5.5 rims that were fitted to VW beetles. the 914 sport rim had a noticeably different offset from the 4.5 and 5.5 rims fitted to the beetle at that time. (IMG:style_emoticons/default/biggrin.gif) ----------- you can never say for sure - but there is a good chance that the red car, sometimes associated with the #1 VW museum car, is maybe one of the two red prototypes amongst the 8 being constructed, visible in this photo of the karmann factory taken in 1968. (the photo can be dated from the front bumpers on the production line karmann ghias). but who knows. it could also be in between the prototypes and the full production cars. whatever it was it was evidently available for use in taking very early publicity photos likely in advance of delivery of any production cars. ------------- i think there were definitely a series of pre production cars that existed before the production line start up. this was definitely the case for at least a few of the cars at the frankfurt motor show launch. there is no karmann plate in the door reveal! ? (IMG:style_emoticons/default/idea.gif) i suspect these are press release cars and were never sold to the public. they may have not had a vin number or chassis identification number that is part of the production sequence. these launch cars also differed from the production cars. fully carpeted front trunks. no seam between the front fender and cowl. they also appeared to lack the central vent in the top of the dashboard that early 4s had. |
| davep |
Sep 11 2025, 11:59 AM
914 Historian ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,382 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
Very nice work, thanks.
| wonkipop |
Sep 11 2025, 04:54 PM
Very nice work, thanks. there is a silver 75 2.0 in the karmann museum collection which is still an intact collection i believe. somewhere at some point i found info on that and going off my memory its supposed to be the last 914 off the production line. i have to try and refind that info, hopefully its not just a deranged memory. if i find the reference again i will post. makes sense that between them, VW and Karmann kept the very first and the very last cars. lots of manufacturers did that. except porsche itself. (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) they sold everything including prototypes they were technically supposed to destroy. (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) |
| JeffBowlsby |
Sep 15 2025, 12:47 PM
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,385 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None
Cool. I am not seeing the jack point condition, are there better photos?
Also, how about this linear cowl-to-fender seam? Attached thumbnail(s) |
| Artfrombama |
Sep 15 2025, 01:25 PM
Artfrombama ![]() ![]() Group: Members Posts: 496 Joined: 21-January 24 From: One of the chosen few Member No.: 27,870 Region Association: South East States
Extremely interesting, great photos.
Thank you! |
| wonkipop |
Sep 15 2025, 06:23 PM
Cool. I am not seeing the jack point condition, are there better photos? Also, how about this linear cowl-to-fender seam? to assist. lightened off exposure. jack point (visible also on original image posted if you zoom in). cowl seams both cars. one has one, one does not. the one that has a seam appears to be a negative joint and not standard VW plastic seam filler moulding of most of the production run. and as you note mr b it does look strangely like a straight line --- linear as you describe it. (IMG:style_emoticons/default/idea.gif) car held in VW museum (said to be #1 car) has no cowl seam at all. filled and flush. which is also a feature of the frankfurt auto show launch cars and apparently as some others have observed maybe the very very early production cars. interestingly neither are like the main run of production cars. but......as i say, the images point to two different cars. the more reddish car with the hubcabs and trim rings is not the tangerine car held in the museum in an earlier state. attachmentid=954360] Attached image(s)
| wonkipop |
Sep 15 2025, 08:58 PM
@JeffBowlsby
it does seem as if that straight line linear cowl seam you picked up on in red car used for publicity shots matches 2 known prototype examples. 914114 (from your website documentation). and also piech 8 (not a clear photo but best i have on file - taken by my mate on a visit to museum about 15 years ago). looks the same as 114. for reference. the jack point on the piech 8. prototype jack point. hard not to think that the red car with the hubcaps and trim rings is a prototype. photographed by VW early on before production run. and used for publicity shots and brochures being prepared before cars were coming off the production line. and for the studio shots was to some extent still unfinished and missing some interior parts. and that the orange one in museum with the 74 beetle sport rims fitted is likely 00001 off the production line. still trying to find the file i had on the silver one held in the karmann collection. which for some reason i believe might be the last car off the line. |
| JeffBowlsby |
Sep 18 2025, 09:09 AM
I see that low jack point now, this is of 914114.
| wonkipop |
Sep 19 2025, 03:15 PM
@JeffBowlsby yes.
the red 4 has body color painted headlight surround mouldings - as it would appear the prototype 6 - #114 also did. along with the lower jacking points. i don't think its unreasonable to say that its very likely the image of the red 4 is a prototype 4. probably one of the handbuilt batch from 68. |
| wonkipop |
Sep 19 2025, 03:30 PM
but the tangerine car held in the collection, (#0001?) - has some differences it would seem from the general production run 70 models.
i came across an interior shot of the tangerine car. (hard to find, only been able to turn one image up that is definitely it). interestingly its got no central demist vent on the dash top as 70-71 models are generally thought to have. similar to all the frankfurt show launch cars. also had no vent. frankfurt launch 4. (def a 4, no floor throttle lever or ignition switch in dash). by dec 69, at least the production cars had the vent. this is about 1,200 cars into production run. ![]() |
| wonkipop |
Sep 19 2025, 03:50 PM
there is also a nice higher def version of the autotest (german tv) episode covering the 914 when launched.
fun to watch as the tv show used the mercedes test track in stuttgart as the fliming/test locztion. nice to see the 914 hanging off the vertical curve the c-111 mercs would have been relentlessly hammering around about the same time. this car seems to be just like the launch cars at frankfurt. have the parallel or linear cowl to fender joint. the #0001 vw car eitehr has this cowl joint or one that is filled and is flush (hard to tell in photos of #0001 car, can't find an image anywhere that has enough res to be able to determine exactly). has no central vent in dashboard. by the time they got to 1200 cars (dec 69) in the production run the cowl/fender junction is the more familiar curved junction with VW panel filler plastic moulding filling the seam. ![]() |
| Rob-O |
Nov 18 2025, 05:54 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,321 Joined: 5-December 03 From: Mansfield, TX Member No.: 1,419 Region Association: Southwest Region
I’m always amazed at how in-depth you get Wonkipop. The Museum would do well to hire both of you as a historians.
Always thought this side marker was cool. I like the production piece as well but these are soooooo unobtainium. Also, the padding between the dash and windshield looks extra thick compared to production vehicles. |
| davep |
Nov 18 2025, 10:20 PM
Those wedge shaped front signal lenses appear only on the prototypes. Unobtanium now.
Lo-Fi Version | Time is now: 11th November 2026 - 06:34 AM |
