| neyen14 |
May 6 2026, 05:19 PM
Member ![]() ![]() Group: Members Posts: 110 Joined: 2-December 07 From: New York Member No.: 8,408 Region Association: North East States |
"Slight gear"? "Total gear"? Not sure what you mean. If the car is in gear and the clutch is good, then turning the transmission should turn the crankshaft. Could there be something wonky with your differential? Limited slip? Welded diff? --DD "Gear" to distinguish between the feeling of pushing past compression versus the feeling of a car being in gear..... I'm wondering if something is stuck near the clutch and flywheel. Anyway thank you all |
Lo-Fi Version | Time is now: 6th May 2026 - 09:13 PM |
