T.Rick6 |
Member ![]() ![]() Group: Members Posts: 64 Joined: 1-October 19 From: Douglasville, Ga Member No.: 23,512 Region Association: South East States ![]() ![]() |
Hey teeners, I need a little help please; does anyone make the adapter harness for a '71 914-6 chassis harness to adapt to a 3.2 engine harness? PMS makes the 914-4 to 3.6 and the 914-6 to a 3.6. I know it's been done before but my search didn't turn anything up. If anyone knows which wires on the 3.2 harness that need to be moved to which position? TIA (IMG:style_emoticons/default/beerchug.gif)
Todd |
Luke M |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,422 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States ![]() ![]() |
Pm Perry @ ironhillsrestorations
He makes engine wire harnesses and maybe able to help you out. Are you running carbs or efi? That makes a big difference in what wires you need. |
T.Rick6 |
Webber 46IDA’s with electromotive HPV-1 twin plug ignition system if that helps…
porschetub |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,926 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None ![]() |
Pm Perry @ ironhillsrestorations He makes engine wire harnesses and maybe able to help you out. Are you running carbs or efi? That makes a big difference in what wires you need. (IMG:style_emoticons/default/agree.gif) Perry did a great job on mine ,cheers. |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,078 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
Patrick makes a 3.2 conversion harness for stock induction but you will want a custom harness if you are using carbs and aftermarket electronic ignition.
Steve |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,932 Joined: 14-June 03 From: Laguna Niguel, CA Member No.: 822 Region Association: Southern California ![]() ![]() |
Patrick makes a 3.2 conversion harness for stock induction but you will want a custom harness if you are using carbs and aftermarket electronic ignition. If you’re looking for the pinouts, do a search. Lots of diagrams. I dumped the relay board when I installed my 2.7 with Weber’s back in 1986 and then moved the pins around for the 3.2 I installed in 2000. You can buy the 14 pin connectors. I recently installed a 3.6 and used the PMS harness. Much more complicated. Than the smaller motors. http://www.914world.com/bbs2/index.php?sho...13517&st=20 https://share.google/images/mTOHfHSJtx5pOxZSD The diagram is for a 75. I would compare it to the wiring diagram for a 71 in the Haynes manual. The diagram is still a good example what the pins are used for. |
Lo-Fi Version | Time is now: 18th September 2025 - 12:20 PM |
