> Tangerine Firewall Bushing - Tips for Installing?, With Engine IN.
FlacaProductions
post Oct 7 2025, 07:19 PM
So....MPS is solved for now - next!
Digging around today, I found that my (as suspected) firewall bushing was in 3 pieces.
So...I'd prefer to go the Tangerine route along with doing all the other bushings.
I know the instructions say that a right-angle drill is needed for the install with the engine in - any tips?
Other ways?
I don't have a right angle drill - any input on maybe a good adapter for my current "standard" drill?
I'll probably go full-boat with the Tangerine system from the firewall back - cuz while i'm in there.....
thanks!
b
emerygt350
post Oct 7 2025, 07:44 PM
Are you referring to the bushing for the shift rod as it passes through the firewall?
FlacaProductions
post Oct 7 2025, 08:04 PM
Yup.
Ishley
post Oct 7 2025, 09:54 PM
Several of your local Chinese tool stores sell an angle adapter for a regular drill. $15.00. Should work for one hole. Or get an angle drill for $44.00.
Geezer914
post Oct 8 2025, 04:13 AM
Geezer914
Rent one from a tool rental shop.
Cairo94507
post Oct 8 2025, 06:46 AM
Michael
Harbor Freight has them cheap. (IMG:style_emoticons/default/beerchug.gif)
GregAmy
post Oct 8 2025, 09:05 AM
QUOTE(Cairo94507 @ Oct 8 2025, 07:46 AM) *
...and then you have a new small hammer when you're done.
Yeah, it's a PITA to get a regular drill in there for the three holes (I did mine with the engine out). But for three holes, the HammerFreight tool will work and be a lot less stress:
https://www.harborfreight.com/38-in-90-angl...ment-69337.html
And that bearing is worth the extra $20 (assuming you don't have a coupon)
NARP74
post Oct 8 2025, 09:08 AM
Milwaukee right angle adapter is 20 bux at home depot. Got me out of a few tight jams on my 914s.
FlacaProductions
post Oct 8 2025, 09:21 AM
Perfect. Thanks folks.
Actually looking forward to this - I suspected that bushing was out or well on its way.
HansJan
post Oct 8 2025, 07:04 PM
Going all-in with Tangerine parts will transform your car.
I did it with the six (firewall bushing, rod and modification at the gearbox).
Feels a little heavier, but really accurate.
5 User(s) are reading this topic (2 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 8th October 2025 - 08:42 PM
