| Superhawk996 |
Oct 30 2025, 11:44 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,959 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
You’re going to have to work with a wiring diagram and a Multi-meter and measure voltage drops until you find the source of your problem.
If the flasher relay seems too hot - start there. |
| black73 |
Oct 31 2025, 03:40 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 519 Joined: 23-March 05 From: Nashville,TN Member No.: 3,801 Region Association: South East States |
Are the rear license plate lights in that circuit? Might check there for short or crossed wires.
| jeff dodge |
Oct 31 2025, 09:42 AM
Newbie ![]() Group: Members Posts: 29 Joined: 5-September 24 From: middleton,WI Member No.: 28,332 Region Association: None |
| Spoke |
Oct 31 2025, 10:02 AM
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,406 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None
It might be useful to check the resistance in the left side turnsignal wiring with nothing powered.
To do this, pull the flasher relay and connect your ohm meter between pins 49a and 31 (ground). You may want to disconnect the NEG wire from the battery before dropping the fuse panel. Connect the ohm meter so you don't have to hold the leads. You may have to jam a wire or a thin piece of metal into the socket for pins 49a and 31. It will be too difficult to hold the probes by hand when doing this testing. With the turnsignal stalk not selecting R or L you should read infinite resistance. When you select the L turnsignals you will read a very low resistance which normally would be the resistance of the bulbs. Pull both front and rear bulbs on the left side and check the resistance. You should measure infinite resistance. If you don't there is a wiring issue somewhere. I would start by removing the wires to the light housings front and rear. If you're still seeing low resistance that means you have a short somewhere. You can pull the L wires off of the hazard switch to eliminate that. Attached image(s)
| NARP74 |
Jul 20 2026, 11:55 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,459 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains |
@jeff dodge Did this ever get resolved? I am having a similar issue.
Lo-Fi Version | Time is now: 21st July 2026 - 06:10 AM |
