2 Pages V < 1 2
> Aux air regulator prototype
emerygt350
post Oct 24 2025, 04:40 AM
Post #21
QUOTE(tomeric914 @ Oct 23 2025, 07:02 PM) *
This is probably just a prototype, but I suggest you make the case out of aluminum to stand up to the heat, or Nylon 6-6 which is good to 450 deg F or so.
When everything is ready I will use the UV resin printer for the final box. That stuff is robust! Once the prototype does (or doesn't) do what I need I will be creating structures to mount it directly to the original mounts and ground through that as well.
VaccaRabite
post Oct 24 2025, 05:55 AM
Post #22
En Garde!
My old MS2 2056 had an ICV based on temps. It used a 3 wire valve from a Kia that cost less then $20, with a printed nozzle similar to yours. I spent a lot of time playing with it, getting the curve exactly where I wanted it for any given temp up to 180*F, when I would fully close. The higher "on" temps made hot starts easier.
I suspect you are going to want more resolution then just on/off. But I'm interested to see what the real world results are on your car.
Zach
emerygt350
post Oct 24 2025, 09:28 AM
Post #23
QUOTE(VaccaRabite @ Oct 24 2025, 05:55 AM) *
Zach
That might be my next move if I need more variable adjustment. I see that kia one is only 15 dollars.
Literati914
post Oct 24 2025, 12:06 PM
Post #24
While trying to decide if I want to keep d-jet for my Volvo 1800E engine build - I was reading up on the components and came across the following, which reminded me of this thread and your endevor for a solution. This wouldn't work in the 914 I suppose, but it's interesting.
"...Aux Air Valve Alternative:
For those that value function over a stock engine compartment, or wish to keep a working fast-idle which does not require arranging for a mortgage to buy a replacement valve, here is a good working manual replacement using a Heater Control Valve [Yes, you read right! There is nothing that says this valve can't control the flow of air instead of Coolant!]
..here is a modestly priced generic Heater Control Valve, mounted in the general original location and manually controlled from the dashboard with a Bowden Cable...a brilliantly simple solution! .."
emerygt350
post Nov 6 2025, 03:06 PM
Post #25
QUOTE(Literati914 @ Oct 24 2025, 12:06 PM) *
I might be headed that way. I have everything setup now and on the car, using a toyota purge valve now instead of the water valve.
Works great, but I just don't think it is worth it. I just feel like a manual lever would be exactly what I want on a car like this. I can also put it inline with the existing setup and just close it when I find the AAR is being annoying.
2 Pages V < 1 2
- Lo-Fi Version Time is now: 25th August 2026 - 08:04 AM
