3 Pages V < 1 2 3
> troubles with ignition 123, Dead dizzy got me dizzy
dtmehall
post Oct 30 2025, 05:29 PM
Post #41
I have what may be a dumb question.
Do you have a ground attached to your transmission?
wbgoggans
post Oct 30 2025, 05:49 PM
Post #42
QUOTE(dtmehall @ Oct 30 2025, 07:29 PM) *
Not at the moment. My motor is out of the car so I am of course not using the trunk mounted ground strap.
Superhawk996
post Oct 30 2025, 06:01 PM
Post #43
The entire fan shroud, case, and transmission should all be the same electrically given metal to metal contact between each of them.
This of course assumes that none of these have been painted or powder coated. Best practice would be to clean any corrosion at the mating surfaces before all these components were bolted together as an assembly. If you’ve painted them, the coating needs to be removed at all mating points.
It will be fine to ground to transmission in the same place the body / transmission ground strap goes. Just clean the trans case up if there is any hints of corrosion at the mounting point.
You could go completely whacko and run separate a smaller 10 gauge grounds to each (shroud & case). Assuming your parts aren’t all corroded up, this is overkill.
fixer34
post Oct 30 2025, 06:54 PM
Post #44
QUOTE(dtmehall @ Oct 22 2025, 07:59 PM) *
The Enshitification Of Everything As Seen In Common Automotive Tools
https://www.youtube.com/watch?v=IegF5gcmBWE&t=51s
I still have that exact Sears timing light. Remember leaning over the carb stacks trying to set full advance at 6000 rpm!
searunner
post Oct 31 2025, 04:29 AM
Post #45
Only for confirm the good affidability of the 123 Distributor-
I have it on my MG TC 1946-Austin Healey 1957- 914/4 2.0 1974- some applications have more than 10 years -and ZERO problems of affidability from the begining-
So my thing is that one of ancillarys - or some conections is wrong
My experience is that the FAR assistence in this particular electronic default is very hard to wear
JeffBowlsby
post Nov 1 2025, 09:26 AM
Post #46
"Affidability" is not a standard English word, but the Italian word is "affidabilità," which translates to reliability or dependability in English. It refers to the quality of being trustworthy, consistent, and able to be relied upon.
emerygt350
post Nov 1 2025, 10:22 AM
Post #47
I like that word! We should add it to the mess that is the English language.
3 Pages V < 1 2 3
- Lo-Fi Version Time is now: 1st November 2025 - 11:30 PM
